WR450F '2012 capricious headlight
2 replies to this topic
  • WRF-Rowdy
Posted May 24, 2016 - 04:48 AM
1) I switch on ignition, headlight stays off, fine so far.
2) I start the engine, headlight stays off, weird, but ok with me.
3) I get going, headlight comes on, stays on.
4) Once it had lit up, it stays lit, no problemo.
5) I kill engine, headlight stays on, cool and ok.
6) I switch off ignition, headlight shuts off.
Is that basically correct?
Does the EFI decide to delay headlight till seizably "after" engine firing up?
The weird part is 2)  :  The time (distance??) the headlight "waits" before beginning to light up varies a lot.
Sometimes it stays off the whole ride from the movies back home (bad), can't be right.
So: What's wrong with my WR, and why?
  • SatansReverence
Posted May 26, 2016 - 02:43 AM
Check your headlight relay and the headlight plug.
Should start with park light > headlight after engine start > Headlight until ignition turned off.
  • Agazza
Posted May 29, 2016 - 02:35 AM
I would like to mount a off switch for trail riding, better to fill up the battery when the sun is out, anyone changed switch?
