Wr400 HID headlight conversion
1 reply to this topic
  • Ryan Bradly Baird
Posted May 19, 2016 - 04:42 PM
Hey everyone!
Just picked up a bikemaster HID conversion kit from my local parts store. The directions that came with it were very unclear. Although i am pretty sure i have it wired correctly, when i flip my headlight switch all i get is a buzzing sound from the relay and the headlight bulb. Any ideas what could be causing that issue???
  • zibbit u2
Posted May 19, 2016 - 11:20 PM
What power source are you using?  Something like that kit should be powered directly from the battery, with the handlebar switch controlling a relay to turn the power on/off.
Generally if a HID system won't ignite, then that means the power source isn't strong enough to provide the initial kick (flat battery), or you've got the system trying to be powered by a AC source versus using DC.  The last possibility is the polarity was somehow reversed which generally kills ballasts immediately.
