Blown fuse?
5 replies to this topic
  • Hypheriox
Posted May 11, 2016 - 10:14 PM
Okay so here's the issue that I am having. I recently put a keyed ignition on my 03 WR450. When I did that I connected all four wires on the key to ignition To my button ignition that originally comes on the bike. When I did that I think I fried something or blew a fuse. But I don't know where it's at. The issue that I am having. Is even if I put a brand new button ignition on their. It comes factory. The lite on the button will not lite up and my electric start Does not work either. I have to kick start it. Even with a brand new button. So I know it has to be somewhere in the wiring and not with the old button. Where are the fuses or is there a fusible link somewhere in the wire.
  • ThrustWasher
Posted May 12, 2016 - 02:39 AM
Have a multimeter?
  • L. Euler
Posted May 12, 2016 - 02:49 AM
Can you provide some sort of sketch for the wiring you did.  I had a 03 WR and am familiar with the power button.  Two of the wires are for system power and the other two are for the light in the switch.  There is a potential to connect power directly to ground if you don't wire it correctly resulting in a blown main fuse.  The main fuse is under the seat near the battery.  If your key switch does not have a light then you only need to connect two wires through the switch: red and brown.  If you inadvertently connect red/black to black (the wires for the button light) through the key switch, you will short out the CDI unit which does not have a separate fuse.
Edited by L. Euler, May 12, 2016 - 02:58 AM.
  • J0nathan27
Posted May 12, 2016 - 03:25 PM
you will need a DVOM meter or a multimeter
  • Hypheriox
Posted May 12, 2016 - 04:54 PM
  • 2012 450 xc-w
Posted May 12, 2016 - 05:27 PM
At least you didn't blow a seal............wait for it......... leaves a bad taste in your mouth.............
