Bought a WR450F. Did I make a poor purchase?
24 replies to this topic
  • Shaz
Posted May 20, 2016 - 02:46 PM
#21
Wow!  Ok, so I was correct in saying that this has been converted to a wet sump.  I verified this by removing left side crankcase cover and inspecting the pathway that leads from the crankcase -> oil strainer -> oil pump -> cover input [B] -> cover output to tank.  The input on the cover [B] has been tapped and plugged with a screw, effectively removing the oil inlet to the tank and making the crankcase the sole oil reservoir, or also known as a wet pump.  I did not remove this screw for the fear of there being another unknown modification somewhere and possibly starving the engine of oil by moving it all to the tank.  If I do decide to keep this modification then I just need to figure out the correct amount of oil to add.
Edited by Shaz, May 20, 2016 - 02:48 PM.
  • 2strokeYardSale
Posted May 20, 2016 - 03:51 PM
#22
Um, it's already a wet sump engine. There is no external oil tank on the aluminum frame models. The earlier steel models carried oil in the frame.
  • Shaz
Posted May 20, 2016 - 03:53 PM
#23
The aluminum frame models carry the tank within the engine casing itself below the crankcase.
  • toten
Posted May 21, 2016 - 04:28 PM
#24
The aluminum frame WRs are an integrated dry sump. Easy to mistake for wet sump but significantly different.
  • Shaz
Posted May 22, 2016 - 01:04 PM
#25
Can anyone give me some information on this wet sump system?  I'd like to convert it back, but I'm not sure if a wet sumo is even suitable for a supermoto.
