YZ450 in the woods? You bet !
27 replies to this topic
  • Jess Choat
Posted May 07, 2016 - 06:32 PM
Posted Today, 06:20 PM
I have scoured the internet looking for as much info as possible to get my YZ450 EFI to handle properly. I am finally close. I will list every modification starting with the most important first, ending with the least important
1)  Rekluse clutch... best mod, I can lock it up sliding into a corner without my hand on the clutch, no engine stalling. I can climb up anything anybody else can, without my hand on the clutch, as slow as I want. This mod alone eliminates the need for larger sprocket and electric engine start, (if there was such a mod)
2)  Remapped for woods riding, lots of low end, very important
3)  Get your suspension set up right, really really makes a huge difference.
4)  Flywheel weight, noticeable with the remapping
5)  Steering stabilizer... I once had the pin fall out and thought I had a flat tire. Really helps with the arm pump, you don't have to grip as hard
6)  Keep sharp tires on, I use michelin S12 XC. The front tire knobs are turned 45 degrees on the extreme edge so they don't fold over and break like so many others. The rear are as good as any other I suppose, its seems the knobs stay square longer and I can climb sloppy clay when they are new
6)  Engine relocation bushings... just put them on and they are coming right back off. Maybe I need to redo my suspension after this mod, I don't know but I went down three times yesterday, once hard over the bars, I don't like them.
I'm older so its important for me to have the best I can so I can keep up with my sons. They are both faster than me but not by much. I dread the day that they won't want to ride with me cause I'll be too slow.
I've seen a lot of posts saying, "get rid of your motocrosser and get a woods bike". Well, I like my bike better than a WR. Its lighter, has more power and the only spendy modification is the rekluse clutch. I think I have less than a $1000 to make it a real woods bike, Its around $10,000 for a new KTM
 The two things I will always have on any bike in the future will be the rekluse clutch and the scotts steering stabilizer
  • GHILL28
Posted May 07, 2016 - 09:36 PM
My 450 does mighty fine in the woods I gotta say.  Put it through its paces today up in the Sierras.  Set up almost identical, except no FWW.  My suspension is on the very stiff side for woods riding, but comes alive when I start pushing it.
I am loving the Shinko 520 rear tire more and more every time I ride it.  The worse the conditions, the better it does.
Don't mess with the engine location.  Just get drop pegs.  It allows the bike to be manipulated much, much easier around slow speed turns while standing.
  • Hakkalugi
Posted May 08, 2016 - 04:49 AM
I ride a 07 yz450 in the woods specifically. So far ive put an IMS oversized tank, smaller front sprocket, GYTR heavy flywheel, .40kg front springs, bark busters with hand guards and some other little things. Its great in the woods and I smoke everyone I ride with when we get to a straight plus its just nice to have the extra grunt. Its awesome that its the 250 frame with a 450 stuffed into it because the bike isnt huge. I'm 5'10" about 140lbs and I ride the bike, the bike doesnt ride me.
  • Jess Choat
Posted May 08, 2016 - 08:37 AM
Ghill...
   Drop pegs?  Tell me more.
  • Jess Choat
Posted May 08, 2016 - 08:39 AM
Drop pegs?  ... tell me more.
  • GHILL28
Posted May 08, 2016 - 08:40 AM
FastWay. Drops the pegs 3/4" or so. Bikes handling comes alive with that.
Also get an 18" rear and tubeless.
  • Jess Choat
Posted May 08, 2016 - 07:03 PM
Tried to buy just the collars for dropping the pegs, $135.00 for the whole peg kit. Not sure if I want to spend that unless it is a for sure thing. How important are they to you?
I forgot to list my 18" tire swap too, you're right, was worth the money, was able to use a taller tire at low pressure, helps to hook it up. Haven't tried the tubeless tire yet.
  • Jess Choat
Posted May 08, 2016 - 07:05 PM
Front springs? lighter front springs?
  • GHILL28
They are critical for me at 6ft. Bars full forward too. Had to make a Scott's mount to run in that position.
  • Hakkalugi
Posted May 08, 2016 - 07:12 PM
Yes, better suited for my riding style & weight.
  • JonL515
Posted May 09, 2016 - 01:19 PM
What year is your bike?  If you don't mind sharing the map, that would be much appreciated.  Still working on one for mine.
  • cowboyona426
Posted May 09, 2016 - 04:39 PM
My 06 YZ 450 was good in the woods but it was never great.  I always wanted just a little bit more range in the gears and better suspension for the trail (even after 2 revalves)... 450FX solved both of those issues for me.  This is the bike I've wanted Yamaha to build for YEARS now.
  • mwtrent
Posted May 09, 2016 - 07:24 PM
I love my 14 YZ450 but the more I ride around in the woods the more I wonder if I would have been better off with a classic woods bike. For some reason the KTM 300 XC-W six days has been talking to me in my sleep.
  • GHILL28
Posted May 09, 2016 - 07:32 PM
Ridden a couple 300s recently and they feel small and awkward and weak.
I'm just as agile going through the trees with this thing. It's weird.
  • Jess Choat
Posted May 10, 2016 - 09:43 AM
You bet... my bike is a 2011 and the map... i forgot but I'll get it and send it to you
  • Jess Choat
Posted May 10, 2016 - 09:44 AM
I gotta ride one, thats the problem, no test rides and I hate gambling
  • cowboyona426
Posted May 10, 2016 - 01:09 PM
I hear that, I was a bit nervous myself especially after the 06 never really fully impressed me but I must say I'm not disappointed in any way with the FX.
  • keeseckb
Posted May 10, 2016 - 01:23 PM
Where in OR are you at? You can ride mine.
  • Jess Choat
Posted May 11, 2016 - 07:14 PM
I'm near newport Oregon, Logsden actually. Thank you for the offer. Where are you located?
  • Jess Choat
Posted May 11, 2016 - 07:20 PM
Both keeseckb and cowboyona426 have great reviews for the YZ450FX. Anyone else have a comparo between the YZ450 and the YZ450FX? By the way, if anyone lives close I have a GYTR tuner for the EFI 450's. You can use it for free if you go for a ride with us.... just a thought.
  • Hot  50 replies
  • 5 replies
  • On January 15, 2017
  • Hot  28 replies
