2014 wr450f wont start in gear anymore out of no where
27 replies to this topic
  • 450crazy
Posted May 21, 2016 - 11:22 AM
#21
  • 450crazy
Posted May 21, 2016 - 11:24 AM
#22
Clutch switch is 18
Edited by 450crazy, May 21, 2016 - 11:25 AM.
  • 450crazy
Posted May 21, 2016 - 11:28 AM
#23
14 is the starting circuit cut off relay.
  • Nathh
Posted May 21, 2016 - 10:49 PM
#24
There is a fuse for the starter motor, it sits right in front of the battery. There's 2 fuses, only one of them does anything the other one is a spare,
your problem could be something to do with those maybe see if the fuse looks alright.
Thats a picture of what I'm talking about.
Other than that all I can suggest is following the clutch switch on the wiring diagram and inspect everything that sits between it and the starter motor.
Goodluck :)
  • Turtlerider
Posted May 26, 2016 - 09:23 PM
#25
Goodluck :)
Clutch switch is 18
Much appreciated guys. Going to take a look at it tomorrow and hopefully i can find something out.
Thanks again
  • Turtlerider
Posted June 21, 2016 - 07:18 AM
#26
Check the diode (19)between the start switch (15)and the clutch switch it also goes to the neutral switch (26)and also check the joint connecter (40)
What is the part number for the diode (19), i think that may be my problem
  • 450crazy
Posted June 21, 2016 - 07:25 AM
#27
Not sure not near my book but here's a good place to find it.
http://www.bikebandi...55575#sch863649
  • Turtlerider
Posted June 21, 2016 - 08:30 AM
#28
Would it happen to be 2 or 3 on "electrical 2" because the pic i posted on the first post here tested bad and is one of the two, but i couldnt find any info on it saying what it was for.
