100 hrs on 2014 yz450f, shim valves or replace them?
Yamaha YZ450F 2014
79 replies to this topic
  • ttr230rider6
Posted May 06, 2016 - 06:02 PM
#61
Yes...
&%$#@!... That delays me to getting it back together till late next week
  • Sheriff245
Posted May 07, 2016 - 04:11 AM
#62
Take the cylinder off carefully, you may be able to reuse the gasket. Always better to replace but sometimes they come off with no damage, and it can save your weekend...
  • ttr230rider6
Posted May 07, 2016 - 06:36 AM
#63
I figured if I'm going to pull the cylinder and everything to do the rings I'm just going to do the the top end while I'm at it. I order a new gasket and new oem top end kit. So I'm hung up anyways :(
Posted May 07, 2016 - 10:17 AM
#64
The base gasket is a steel shim type, and cannot be reused.
  • Aaron_Baker
Posted May 09, 2016 - 11:34 AM
#65
I've got a 14 450 it just started getting hard to start checked the clearance and the was no gap here's a valve out of it its done about 120hrs now I
  • toten
Posted May 09, 2016 - 11:42 AM
#66
I'm impressed that it ran at all with no gap. Have you done valve checks/adjustments before? I don't see a picture either.
  • Aaron_Baker
Posted May 09, 2016 - 12:04 PM
#67
The smallest gauge I had was .03 and that wouldn't go in tbh it ran alright once it was going. I did a full build on it about 25hrs ago and they was OK then
  • Aaron_Baker
Posted May 09, 2016 - 12:06 PM
#68
They must of just decided they've had enough lol
Edited by Aaron_Baker, May 09, 2016 - 12:07 PM.
  • GHILL28
Posted May 09, 2016 - 12:42 PM
#69
Fortunately OEM valves for this bike are pretty damn cheap.
Edit:  Head assembly is only ~$335 too.
Edited by GHILL28, May 09, 2016 - 12:44 PM.
  • Aaron_Baker
Posted May 09, 2016 - 12:59 PM
#70
Not here in the UK they was about £50 each
  • toten
Posted May 09, 2016 - 02:15 PM
#71
In that case it might not be a bad idea to get someone in the US to send you a new complete head. Not that much more than new valves.
  • ttr230rider6
Posted May 11, 2016 - 05:07 PM
#72
Does this cylinder need to be honed? You can still see the lines going horizontally and doesn't seem glazed but I'm not sure. What do you think ImageUploadedByThumper Talk1463015241.157308.jpg
  • Sheriff245
Posted May 11, 2016 - 06:45 PM
#73
That side looks great to me.
  • ttr230rider6
Posted May 12, 2016 - 02:30 AM
#74
So if the whole thing looks like this you wouldn't worry about getting it honed?
Posted May 12, 2016 - 06:25 AM
#75
I'm a huge proponent of using ball hones on Nikasil four-strokes, but that one simply doesn't merit doing it.  Clean it up with a Scotch-Brite and run it.
  • Sheriff245
Posted May 12, 2016 - 08:58 AM
#76
I would put it back in as is, no honing.
  • ttr230rider6
Posted May 14, 2016 - 12:55 PM
#77
Well guys I got it all finished and I have the bike broke in!! I must say it went pretty smooth and thanks to all you guys for helping out answering my questions! I really appreciate it. I pretty much followed the same break in period as the Manual recommends (I did the same when it was new) and everything seems to work flawlessly with no leaked or anything.
I think a little bit of coolant got in the bottom end when I was taking it apart. So I refilled with new oil and And after the initial start up, of Idling for a few minutes, I drained the oil again and it was a little cloudy. So I refilled it again and did my break in. Going to dump the oil again tomorrow and refill it again.
  • dougla12
Posted May 14, 2016 - 06:33 PM
#78
What website to order from?
  • GHILL28
Posted May 14, 2016 - 07:00 PM
#79
BikeBandit, Chapparal, RockyMountainATV, etc etc
  • Edge316
Posted May 14, 2016 - 07:35 PM
#80
If anyone's interested there's a 16 yz450f head for sale in Thumper talk classifieds. I believe the guys asking 350.00...Seems like a smoking deal for a head with 5 hours on it.
