100 hrs on 2014 yz450f, shim valves or replace them?
Yamaha YZ450F 2014
79 replies to this topic
  • jz125
Posted May 03, 2016 - 12:15 PM
#21
Kinda shaking my head here. Do you own a Yamaha YZ450F?
Just ride it
  • ttr230rider6
Posted May 03, 2016 - 12:47 PM
#22
What is the point in replacing something that isn't worn out?
The rings can start to loose their seal before any significant wear to the piston occurs. In this case, neither of these components is necessarily signaling that it needs immediate attention by showing symptoms of wear, so the tear down will amount to preventative maintenance. In such cases, you inspect what you find and decide whether it needs attention or not. In general, unless the rings are nearly new, you should replace them if you pull the cylinder off. Whether to replace the piston becomes something like predicting the future. You can observe and measure the wear you find, then take an educated guess as to how long it will last before it really needs attention, then balance that against whether you want to put it together now, then take apart later to replace the stuff you don't do now, and against the fact that if it isn't completely used up, you're throwing money away in the form of use you didn't get from it. All this considering that it's much more expensive to wait until something breaks to fix it, and that risk increases the longer you leave things together.
Thanks for the info man, really appreciate it. 2 more questions before I start.
1. Should I drain the oil before I start?
2. how can you tell by looking at the rings of they are worn out or need replacing?
Posted May 03, 2016 - 12:52 PM
#23
1) Doesn't matter, but it's a good idea to change the oil after the engine's been opened up.
2) Measure the end gap per the manual instructions.  As the ring wears, the gap widens.  If you remove the cylinder, just plan to replace them.  They're only $20 a set or so.
  • adam8781
Posted May 03, 2016 - 02:40 PM
#24
replace the damn rings,  They are cheap, If I owned the bike it would be getting a 13.5:1 piston lol.
  • ttr230rider6
Posted May 03, 2016 - 02:44 PM
#25
Just ride it
Doesn't matter what it is, it still has to be maintained
  • GHILL28
Posted May 03, 2016 - 03:04 PM
#26
Why?
  • adam8781
Posted May 03, 2016 - 03:11 PM
#27
Blow by ruins oil, accelerates wear etc. Its a very cheap easy thing to replace. These bikes are 1/8 an indy car motor. If the motor is open, hes 4 bolts away.
Not the end of the world if you dont but a 14 yzf is a pretty penny, I dont mind spending a nickel here and there to keep it in top shape.
  • GHILL28
Posted May 03, 2016 - 03:17 PM
#28
No I meant the high comp piston.
  • ttr230rider6
Posted May 03, 2016 - 03:41 PM
#29
Got the valve cover off and I am only seeing 4 valves?! I thought the yamahas had 5? Or did they change it in 2014??
EDIT: I know now it is 4 lol
Edited by ttr230rider6, May 03, 2016 - 05:44 PM.
  • ttr230rider6
Posted May 03, 2016 - 05:25 PM
#30
I will get the correct measurements in the morning. I was going by the wrong specs in the book. I didn't read the full thing and I went on an assumption I was doing it right. I will be much more careful and will read more in depth from now on
Edited by ttr230rider6, May 03, 2016 - 06:20 PM.
  • GHILL28
Posted May 03, 2016 - 06:05 PM
#31
Where the hell are you getting those numbers?
  • ttr230rider6
Posted May 03, 2016 - 06:11 PM
#32
Oh my god, I was going by valve guide specs in the manual, i am an idiot. I just went through the manual and I found the correct numbers. I assumed I was reading the right section and assuming always screws me over. I will get the correct measurements in the morning.
Edited by ttr230rider6, May 03, 2016 - 06:18 PM.
  • GHILL28
Posted May 03, 2016 - 06:37 PM
#33
.005-.008" on intake
.008-.010" on exhaust
  • toten
Posted May 03, 2016 - 07:45 PM
#34
At least you figured it out before screwing anything up.
  • ttr230rider6
Posted May 04, 2016 - 01:51 AM
#35
Just checked them again, here is what I recorded
The exhaust valves are still within spec (0.2mm-0.25mm) and the intake valves are slightly out of spec (0.13mm-0.2mm)
Going to remove my intake cam after work to see what size shim is in there now so I can figure out which size I need.
  • ttr230rider6
Posted May 04, 2016 - 04:15 AM
#36
Got that right! I'm pretty sure I got it under control now
  • GHILL28
Posted May 04, 2016 - 07:51 AM
#37
You are positive it's below .013mm (.005")?  Mine measures EXACTLY at that limit and hasn't budged.  I would double check before you mess with it.
  • ttr230rider6
Posted May 04, 2016 - 09:33 AM
#38
The 0.005" feeler slid in with a little bit of stickyness to it. But the number in mm on the feeler said 0.127 mm, but when I convert 0.13 mm online it comes out to 0.005118, which is bigger than 0.005 so really I am still in spec? But shimming it 0.05 mm would obviously help it by putting it up around 0.18 mm
Posted May 04, 2016 - 10:00 AM
#39
Those are the specs for the old 5 valve engine.  for the '14, they are:
Intake:  0.13–0.20 mm (0.0051–0.0079 in)
Exhaust:  0.20–0.25 mm (0.0079–0.0098 in)
  • GHILL28
Posted May 04, 2016 - 10:02 AM
#40
That's what I just said, with .0001"-.0002" of rounding, since tenth's aren't measurable with feeler gauges anyway....
I would leave it.  Maybe check them every 20h and adjust once it's actually OUT of the range.
Yamaha Recalls Off-Road Motorcycles Due to Crash Hazard by Bryan Bosch
  • 7 replies
YZ 450 2014 LOOSE FRONT END by Envisage
  • Hot  141 replies
Yamaha YZ450F 2014 by ThumperTalk
Yamaha YZ450F 2014
  • 35 reviews
  • Last review by Gode
  • On November 10, 2016
2014 Small Complaints - Filter Dirt / Gas Cap / Oil Screener by savagex
  • 3 replies
Cycra Powerflow Plastic Kit YZ250F/YZ450F (2014/15) by Quake
Dirt Bike   Make / Model Specific   Yamaha   WR/YZ 250F
  • Hot  42 replies
