Home made YZ250 expansion chamber
During my YZ250 rebuild project, I looked at the smashed up factory exhaust and got the crazy idea that I wanted to tackle a custom exhaust. How hard could it be, right?
After taking measurements, and crunching numbers, and comparing to the stock pipe, I came up with a model that I thought would work well. Aiming for a little more, little lower, and little broader power, but as long as it didn't suck I would be happy. I mostly wanted it to look cool!
This is the adjusted model I came up with in solidworks.
13086947_1152494851451359_87328924441922
From there, I segmented it into 35mm sections. 32 of them in all not including the stinger and the header stub. From the solid model I measured the diameters at each 35mm section and built a spreadsheet to keep track of each cone section. Now the fun begins!
Piece by piece I would make an educated guess for the mieter angle, printed out each section, cut it out, taped it together, and tested it's fit, then repeat the process until it was right... Then start the next piece. I don't know how many trees had to die for this process, but their sacrifice was for a good cause.
12592276_1139078069459704_51343487244909
12592607_1139078089459702_22149089181885
12112505_1139078212793023_51579586908679\
12919708_1139078239459687_87790817219883
The next step was optional, but cool and a good way to confirm the fitment. I recently got access to a 3D printer, so why not test it out?
12923092_1139078116126366_40746928035974
1174606_1139078312793013_929128192866172
12974542_1139078396126338_16565908369034
11246177_1139078419459669_40337180908613
12931210_1139078552792989_13573614257839
  • Like 9
With a little super glue magic...
12936586_1139095279457983_85337759291372
12961470_1139095299457981_87405753848607
Now I was 99% sure it would fit. Back to your regularly scheduled fabrication!
I took each cone section and modeled it as a 20ga. sheet metal part in solidworks, and then flattened them out, and had the pieces laser cut out of stainless steel.
Looks like a fish... sorta.
13051783_1151335778233933_46243618810081
Now on to the next hurdle. How the hell am I going to get these flat pieces into round pieces??? I could just hand shape each one, but the farther off round each one is, the harder fitment will be to the other pieces. So I made myself a little slip roller!
13082630_1151335794900598_27077476147133
13083176_1151335831567261_34473175140578
12115823_1151335874900590_83188000175244
13043591_1151335911567253_20161612447883
In the end, I still had to do quite a bit of hand tweaking for each section, but the roller helped a lot!
Tick tack weld!
11215777_1151335934900584_69178691999972
After that, it was time to machine the header stub, also from 304L, of course! I made and broke two cutter tools for the oring grooves. Not fun! Finally I ground a custom cutter out of a solid piece of tool steel and that worked like a charm. Should have just started with that, but I'm lazy I guess...
13095779_1151335948233916_67949639141062
  • Like 4
Now it's finally starting to take shape!
You can see by my crossed out marking that some of the sections were very similar to each other. Make sure to double check your measurements kids! :smashpc:
13043756_1151335968233914_45406603776002
... Except for some pieces that didn't get cut right... They must have shifted in the machine or something. Not exactly what I want to see after spending $170 to have these things cut out, but what can you do but work with it?
13102750_1151336021567242_67398441734615
13055515_1151335998233911_11138221531503
The magic of fast forward...
13102620_1151336061567238_46056364410821
Presto! Pipe-oh!
13055347_1151336101567234_44120824822084
Well, almost. It fits, not it's time for the final hurdle. Welding everything together! For anyone that cares, I'm no pro at welding to say the least. I've never taken a class, and aside from watching youtube videos, and asking pointers, I'm 100% self taught on various projects. Needless to say I was pretty intimidated by butt welding 20 ga. stainless, when the welds need to be cosmetic. I really, really, REALLY wanted it to look good, not have some nasty bird poop explosion welds!
For anyone that cares. Back purge with argon is a must, 1/8th tungsten, 1/8th 308L filler, around 35 amps (I was using pedal control) Gas lens with maybe 15-20 cfm, and a 5 cup. The machine was an old transformer miller synchrowave 300 that's probably twice as old as me, but it got the job done just fine!
Pause, dab, move, pause, dab, move...
I'll spare you the 7 straight hours of welding and skip to the results!
13100908_1151336198233891_69572898524876
13055556_1151336218233889_78099099907380
13094123_1151336268233884_78980302145703
It did warp a tiny bit because I did most of the welds on the inside first for practice, then did the outside where you could see them.  :naughty:  Not the best idea, but it worked, and I just had to stick a pipe in the header and give it a few grunts to get it spot on!
13096038_1151336294900548_76642214876538
The final step was to add all of the little tabs and weldments that would keep the dang thing on the bike.
13091918_1151336364900541_56300054152076
Note that I ended up welding the gaps on the stinger... what is that ring spacer silencer sealy thing called anyway? Anyway I ended up welding them because it was leaking smoke when I test rode it.
13083333_1151336411567203_83088356659119
13055493_1151337018233809_79239161903547
  • Like 7
A couple shots of the welds. They aren't perfect, and they aren't even all this good, but I'm pretty tickled with how it turned out!
13094364_1151336174900560_62661414113234
13095924_1151337578233753_83132569579102
13083277_1151338251567019_97332830680625
Evolution, or creation?
13043651_1151338358233675_23554576638605
Turns out it's a hair lighter than the stock one, too. I'll be faster for sure!
12107192_1151338418233669_81920554806818
13094340_1151338448233666_75326384804985
Ride report. I only have maybe a half an hour seat time on it, but I swear it pulls harder than the stock one. Maybe I'm just dreaming, and like I said I honestly don't care as long as I can't notice that it's worse. I still need to tweak the jetting too. It seemed almost perfect when I rode it, but it was also only 50f so I'mm probably drop the main and pilot a size or maybe two when it warms up more... Still not an expert on two stroke jetting... I wish I could dyno it, but for now I'll just have to say by the seat of my pants that it was a success! Plus it looks amazing if I do say so myself, and who cares how fast you are as long as you look good... Right??
13062486_1151338618233649_57567066205395
13102679_1151338871566957_11708808605925
13096236_1151338961566948_65106577495770
13096213_1151338988233612_11401922986662
  • Like 16
 OP, Where did you get the data for measurements on your project pipe?
Its basically a mashup of measuring the existing one, using programs to calculate it, math from the two stroke tuner's handbook, and of course a healthy dose of pulling numbers out of my ass/going with my gut for what "looks about right". I ran quite a few calculations for different tuned results and compared the results. For example, a smaller, more gradual expansion chamber yields a smoother power curve. That made sense to me, especially comparing it to a trials bike which has pretty much a straight header and rides like a four stroke as far as power curve goes. Compare that to the stock pipe diameter X at length Y so I didn't end up with something that was WAY off, then blend it all together for a nice average. Smooth out the transitions some and that's about it.
Holy shit! Dunno what you do for a living, but you have endurance and talent!
Funny you don't change the front tire which is toasted... Out of laziness? :jawdrop:  But you go ALL IN on the exhaust? LOVE IT!!!
Yeah, the original plan was to rebuild the motor, and suspension on that bike but keep the rest of it rough so I wouldn't have to worry about thrashing on it... Now I got this pipe... oops! ?  I'll change the tire eventually, but I pretty much burned up my budget for the rebuild because the motor had a lot of unforeseen problems that added up fast. There's a couple miles left on it anyway :ride:
  • Like 2
Ha! I hear ya. I wish I lived close to you, I would give you a tire for free. Your effort, commitment stands out for me.
Holy crap man. NICE WORK! I have to admit, when I read the title I figured it was someone asking if it could be done, or some haphazard attempt. You on the other hand went balls to the wall and created a very well documented masterpiece.
You might have a future in a side business building custom expansion chambers. The welds really aren't that bad either. If you did a few more of them you'll be surprised how fast you get good at it.
Once again, impressive!
