Help with Breather Hose "T" mod
5 replies to this topic
  • eBayThumper
Posted March 23, 2002 - 11:01 AM
Hey All,
I recently heard that some of you have placed a T in the breather hose so in case you get into deep water the hose will not suck up water. I would like to know what type of "t" you all have used.
I guess I could just go for it but if you have a slick fitting solution please share...
Thanks as always and Ride On...
J
  • John_Lorenz
Posted March 23, 2002 - 11:41 AM
:) I use earl grey with a twist of lemon
Dang laptop keeps updating me every time My hands croses the pad.
as I was saying, With that I also just run WFO this causes the hydroplane effect and submersion is never a factor. the only people I notice under water are squids
[ March 23, 2002: Message edited by: EgoAhole ]
  • keith
Posted March 23, 2002 - 11:51 AM
i found some tee fittings at Home Depot , in the sprinkler section . they were for a plant watering system , and have held up so far . Applied Racing makes an 8mm crankcase vent filter. it looks like it could work , i wonder if anyone has tried one , and what were the results ?
  • dirtdad
Posted March 23, 2002 - 12:55 PM
go here: http://www.unruhly.n...info/index.html
search down the page. I think what you're looking for may be referenced there.
  • sirthumpalot
Posted March 24, 2002 - 05:19 AM
I don't know first hand, but I've heard that some people get the Ts at a pet store which has aquarium equipment (they're used for the areators). I heard this a long time ago and I have no idea if they have Ts that will fit the size hose that is on our carbs, but it's worth a shot if you cannot find it anywhere else.
  • eBayThumper
Posted March 26, 2002 - 07:38 AM
:D Thanks All,
Ego, If I hadn't read several of your other posts, I'd take offense to that comment :D Ego is the "I" in team and there aint one!
Keith, Dirtdad, and sirthumpalot,
Thanks for your input. I was thinking of just cutting the breather shorter but I think I'll try to find a fitting at the Depot that will fit.
I wasn't even thinking of the carb breathers...I didn't know they 'sucked' too :)
I like the re-route into the airbox thing...that's pretty slick...I wonder if there is any conflict of interests there...there's lots of suction in that box.
Anyway, I'll probably give it a try and see what happens.
WFO on Earl Grey Tea...sounds like a real hellion!
Take Care All,
J
  • Hot  50 replies
  • Hot  36 replies
  • 10 replies
