'01 or '02 with a slight bog off idle?
2 replies to this topic
  • skthom2320
Posted March 22, 2002 - 08:34 PM
Guys, I'm so damn happy right now I have to share! I have an '01 426. My bike has never had an off-idle "stumble" or bog off-idle (at least when the fuel screw was adjusted right :) ). Until recently. The last 2 weekends I've noticed a bog off idle that I couldn't get rid of with fuel screw adjustments. I'd turn it in to lean it out and get a hanging idle. Turn it out to richen it and it would get worse. Arrgh.
Did I over-oil the last two air filters? I noticed the last time I put one on it was pretty heavily coated. So I cleaned 'em up and *lightly* coated them with oil last night. I reinstalled one today, started the bike up, and damn if I didn't still have the bog. I messed with the fuel screw again and verified the same behavior as before. Crap. Now what?
Well, since I had a feeling that I had over oiled the air filter, I took the carb completely apart and cleaned it real nice just now. Even installed the slide backward just for kicks. :D Once I redid the slide and got everything buttoned back up, I started the bike up. Wooohoooo! No more bog!
Must have sucked some oil in the pilot air jet or sumpin' like that.
Anyway, I thought I would share so the newer members can recognize these symptoms and start with a clean carb before they mess with jetting. BTW - my jetting is completely stock right now (about 65 degrees, sea level) with fuel screw adjustments daily to compensate for temperature.
  • John_Lorenz
Posted March 23, 2002 - 04:44 AM
:) Yippie for you
Ya the 426ers really need to breath, my 00 is tempermental that way also in Northern CA. If depending on the day I may have to run up one Main or Down a main. I even keep spare Filters(Wrt Bros / K&N) and the stock. Its funny on wetter days / High Moister Colder days I run the Stock filter with a 165 Main also bring the needle up one. No Bogs No Hogs, Strangly though I did the BK mod and that little peie of trickery really made the diff on exiting corners on roll on, man she snaps up like a 250 and excels real hard
  • Scott_in_KC
Posted March 24, 2002 - 08:34 AM
That little PAJ is just begging for something to plug it up! Good job, glad you found the patience to just take it apart and clean it before you freaked.
  • Hot  50 replies
  • 3 replies
  • Hot  47 replies
