04 yz450 won't start. What am I missing?
4 replies to this topic
  • bikridr69
Posted April 17, 2016 - 07:39 PM
my buddy's 04 yz450 won't start. Put a new head and piston and rings on it. It started n ran but had a ticking/knock, sounded like from the top end. Checked the timing and it might have been a tooth off. Changed that and put it back together. Now it won't start at all, only tried kicking it.
  • defilmcrew
Posted April 17, 2016 - 11:18 PM
I would check timing again first. Also is there compression after reassembly? If not or low check for a bent valve (cup stuck partially down)
  • bikridr69
Posted April 18, 2016 - 03:00 AM
It has compression (I didn't measure it with a tester) but feels the same as before when kicking. I will check the timing again and check for bent valves after work.
Edited by bikridr69, April 18, 2016 - 03:03 AM.
  • toten
Posted April 18, 2016 - 06:13 AM
The easiest way to find a bent valve is excessive clearance.
Posted April 18, 2016 - 06:28 AM
If it has normal compression, why would you suspect bent valves?
  • Hot  36 replies
Motocross
  • Hot  491 replies
  • 10 replies
  • Hot  50 replies
