Chain guide replacement
5 replies to this topic
  • rhinoracin
Posted April 17, 2016 - 01:02 PM
Will be getting new sprockets, chain, adjuster blocks, and some other stuff for my YZ soon, and I'm thinking about doing the chain guide and maybe chain slider too. The stock slider and guide are still in good shape, but is the stuff from TM Designworks worth the money, or are they not as good as they look? I don't really need their top of the line parts, so is their cheaper stuff still better than stock?
Posted April 17, 2016 - 01:14 PM
... is their cheaper stuff still better than stock?
Not really.
  • Betarocker
Posted April 17, 2016 - 03:03 PM
I replaced my stock guide with a TM Designs. The OEM guide was soft-ish plastic/rubber liner in an aluminum frame. Once the frame was bent in from either crashing of hitting something, it wore out the side of the guide liner and also wore down the master link clip. The TM is a harder and slicker material and also has some elasticity so when it gets banged, it returns to its original position.
  • RMK800
Posted April 17, 2016 - 03:46 PM
I replaced my sons crf250X with the chain guide from TM. Seems very durable, however, it's freaking noisy. I can still hear it after a year. I would rather run oem.
  • jamiehughes
Posted April 18, 2016 - 03:45 PM
The TM premium stuff is good stuff..not cheap tho..i had both the rear block and slider on my 06 yz450f.. they never wore out in the 7 years i owned it.  the factory stuff wasn't worn out either, they got got jacked up when my rear hub broke on the bike the first year i owned it
  • Wiz636
Posted April 20, 2016 - 07:02 AM
I've ran TM Designworks, Acerbis, and Primary Drive chain guides and they all seem to perform about the same. The Acerbis gets a little closer to the rear sprocket than the others.
Ditch the stock guide with the aluminum body as they will not spring back into place if they take a hit and bend.  I have always removed mine immediately and save it for when I am selling the bike.
  • Hot  491 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
  • Hot  79 replies
  • Hot  33 replies
