2011 YZ450F - Only bump starts
14 replies to this topic
  • kjh440
Posted April 17, 2016 - 12:02 PM
Having an issue trying to diagnose new to me 2011.
I have a 2010 which has now issues.
When I bought the 2011, went through and replaced timing chain. Put it back together and kick started ok. Sat through winter, now it will only bump start. I had both bikes side by side today doing some work. Swapped coils as I had an issue with my 2010 couple of years ago. Still no luck. Bump only. When it starts, it runs well. Stop and immediately try to kick - no go.
Checked timing again, spot on.
A little stumped as to what to look at next.
BTW  no codes with programmer. Bike has 60 hrs on it.
Thanks
kjh
  • billygildark5007
Posted April 18, 2016 - 10:45 AM
Is the valve clearance correct?
  • kjh440
Posted April 19, 2016 - 02:53 PM
Valve clearances were all in spec. I checked when I changes the chain.
  • 2005yz250fbb
Posted April 19, 2016 - 08:35 PM
Plugged injector or fuel filter?
  • billygildark5007
Posted April 19, 2016 - 10:15 PM
Edited by billygildark5007, April 19, 2016 - 10:16 PM.
  • F0Xryder61
Posted April 21, 2016 - 08:48 AM
I cleaned my injector with the same symptoms that you have and it made it better. Still need to buy one
  • kjh440
Posted April 21, 2016 - 03:34 PM
Thanks for input. I will check injector this weekend. Look at fuel flow.
  • Rexxxsi1989
Posted April 21, 2016 - 07:11 PM
Clean all the electrical connections also as that's all it took for mine when it was having problems.
  • kjh440
Posted April 24, 2016 - 12:33 PM
Update. Got a chance to look at it today. Cleaned all connectors. Rechecked valve clearances.
Checked out the injector. Put a rag under the throttle body, it did get wet with fuel after a few pushes on the kick starter. Put in injector cleaner and ran it around the yard and let it idle.
No matter what - still no kick start. Only starts by bumping.
A little frustrated.
What am I missing?
thanks
kjh
  • tomerb
Posted April 24, 2016 - 02:14 PM
Did you check the spark when using the kick start by pulling the plug?
Posted April 24, 2016 - 04:48 PM
What it sounds like to me is a check valve problem in the fuel pump.  The injector needs fuel pressure at about 45 psi to fire.  That's why it frequently takes more than one kick to start them.  Fuel pressure may not be high enough yet when the injector pulse comes, but gets built up by the end of the kick.  Then the next kick the pressure is high enough, and it starts.
Something has to hold the pressure you raised on the first kick, or it won't start on the second one, either.  That's a simple one-way valve called a check valve.  If, as I am almost certain, the system has one, it's in the fuel pump assembly.  You can test it if you can get a pressure gauge connected to the thing somehow.  Pressure should rise on the first kick and stay elevated for at least a minute.
  • tomerb
Posted April 24, 2016 - 05:28 PM
If you think its fuel, shoot some starting fluid in it and see in it starts no need to hook up a gauge to the fuel pump yet.
  • kjh440
Posted April 30, 2016 - 11:45 AM
Update.
Swapped fuel tank/pump from my 2010. No difference.
Took out the injector - cleaned.
Cleaned stator connectors
Check plug -spark ok
Still only bump starts - no kick.
When started - runs well.
Pushed to back for garage for day.
Any suggestions what to look at next.
Swap ECU?
  • kjh440
Posted May 01, 2016 - 07:05 AM
This morning swapped ECUs but still no difference.
  • DanielMerrick
Posted May 01, 2016 - 05:04 PM
leak down test ? had an older bike that would not start by kicking it because of low compression but after a good push down the trail it would fire.
  • On January 15, 2017
  • Hot  36 replies
  • Hot  47 replies
  • 5 replies
