Chain wear on sub-frame and frame
7 replies to this topic
  • Ronnie Mac
Posted March 09, 2004 - 06:56 PM
After seeing wear, and hearing the slaps on the sub and main frame, :) I adjusted the chain to the min slack. It took care of it, exept under low rpm excel. Anyone have a cure for this?
  • tctrailrider
Posted March 10, 2004 - 02:30 AM
Check the Tech articles, his correction works great. :)
  • ddialogue
Posted March 10, 2004 - 02:05 PM
As previous post shows, there is a link to Motoman393's forum for a quick, cheap fix. You can also replace the stock swingarm buffer with one from TMDesignworks. Twice as thick and doesn't shuffle back and forth like the stocker does.
  • wrooster
Posted March 10, 2004 - 06:24 PM
jim aka the wrooster
'01 wr250f
  • Ronnie Mac
Posted March 10, 2004 - 08:29 PM
Thanks everyone for your response.I will let you all know if this mod works for me. It might be a day or to to let this cold air to pass threw. Thanks again for your time. :)
  • Indy_WR450
Posted March 19, 2004 - 04:43 PM
Ditto Dave. I have had my TM design slider on for almost a year. It does not slide and does very well at protecting the swingarm. It is very thick compared to the stock unit. :)
  • Ronnie Mac
Posted March 19, 2004 - 07:04 PM
Hey Indy most of the wear is on the alum sub-fram suport,left of the swing arm. Is this the wear everyone else is talking about? On mine the chain slaps to the side. :)
  • Indy_WR450
Posted March 20, 2004 - 08:36 PM
No they are talking about the actual swingarm wearing under the stock slider due to chain slap and the fact that the stock unit slides around a lot. Your issue is something different. :)
