Hard starting 99 YZ400 need help
7 replies to this topic
  • Steve_Gille
Posted March 21, 2002 - 05:07 PM
I am a new owner of a 99 YZ400, witch is very hard to start and will not start some times.I am using the correct starting technique by bringing it to TDC and not touching the gas.When it done's start it takes about 20 to 30 kicks, then it will backfire and after another 5 or 10 kicks it will start sometimes.I just replaced the throttle cable do I need to adjust the throttle position sensor, it has started since I replaced the cables. I have read about the BK mod and disconnecting the blue wire on 2001 and 2002 models will this help on a 1999 yz400.Please help I love the bike but if it is going to be this hard to start I am selling it real soon.
  • rpadgett2
Posted March 21, 2002 - 05:34 PM
What you need to do is bring the motor to TDC. Then pull in the compression release and push the kick lever about 2 inches. If the motor is cold turn the throttle one full turn. Then give it a good full kick. If the motor is hot just don't give it the gas. I have a 99 400 and this works every time. I don't even use the hot start button. Hope this helps.
  • gearbri
Posted April 02, 2002 - 01:26 PM
hey... Im wondering what you guys can tell me about your 99yz400's... I just found one here in colorado and am strongly considering purchasing for $3299, what should i know going into this bike?
  • rmarion
Posted April 03, 2002 - 05:58 AM
I'd suggest that since your a new owner and you don't know how it was maintained. Clean the carb and all the jets out, change oil, clean air filter, (do not install a freshly oiled filter, let dry overnight, if freshly oiled, the oil might get sucked into the jets) install a new plug and fire the BEAST up. I have a 99YZ400, it has the original plug in and starts up 1st- 2nd kick.
  • humbertob
Posted April 03, 2002 - 06:10 AM
The YZ400F is a great bike, the only thing it needs is a wonderful preventive maintainance. Change the oil every 10 hours of use or before and your engine will last a long time. I'm using MOTUL 5100 every 10 hours of use on my YZ400F Beast and oiling the air filter every 3 rides with awesome results, grease or lubricate your chain every ride and clean or replace the oil filter every 3-4 oil changes and you'll be great on your BEAST ! I'll bet you !!! :D
I love mine, but the YZ400F is Preventive Maintainance Hungry all the time !!! :)
  • skthom2320
Posted April 03, 2002 - 07:47 AM
How does it run when it finally starts? Are there any flat spots? Does it pop or backfire? If it runs OK after getting it started, there is something wrong with your starting technique. Since it is backfiring, it sounds like it is getting too much gas somehow. Are you sure your throttle cables are adjusted properly? BTW - if you were messing with the pulley while you were adjusting the cables, then you would have sent some gas into the intake through the accel pump.
Let it sit overnight, put in a fresh plug (you can get the NGK CR8 at O'reilly for $3, their part #1272) then do the drill. Do a search for "starting drill" and you will find plenty of info.
  • thumpsalad
Posted April 03, 2002 - 01:44 PM
Rejet the bastard. Mine had stock jetting and an FMF Power Core 4 pipe and it was a BEAR to start. I re-jetted to a 175 main from a 168 (i think).
Now, it starts in 2 or 3 kicks hot or cold, no hot start!
  • Guest_Guest_*
Posted April 03, 2002 - 04:19 PM
I have a 98 yz400 It starts great, but I have talked to people who owned a 98 and a 99. They said the 99 started hard they tried everything. It ended up being a fuel problem not jetting but the fuel itself. The reason for this I don't know being the 98 ran on that fuel, maybe jetting. Thy guy I bought my bike from told me it ran best on 95 octane without alcohol. Give it a try it may be a cheap fix.
  • 0 replies
  • Hot  36 replies
  • 5 replies
  • On January 15, 2017
