Stripped sub frame
8 replies to this topic
  • dhend8
Posted April 11, 2016 - 04:25 PM
I just notice a couple days ago that the bolt that holds the sub frame to the frame was missing. So today I got a new bolt tryed putting it in and i noticed it was stripped. Any suggestions on what I could do? Would loctite do anything?20160411_184533.png
  • filterx
Posted April 11, 2016 - 04:44 PM
You could try tapping it with the same size tap first and use a new bolt first. If that doesn't work then re-tap with the next size up. Absolute worst case would be to drill it out smooth and use a new bolt with a nut on the back but before you do that...
If you can take it to a good machine shop or mechanic and see what they suggest
  • cesper
Posted April 11, 2016 - 04:58 PM
Time-sert would be the absolute best thing. They are pricey, but if you remove anything in the way and take it to a shop that has them, shouldn't be more than 0.5 labor or something like that.
  • filterx
Posted April 11, 2016 - 05:01 PM
And yes there will be some good other options
  • Jlash
Posted April 11, 2016 - 06:12 PM
drill it out, tap it, and install a helicoil of the original bolt size
  • ThrustWasher
Posted April 11, 2016 - 06:56 PM
Put the same thread bolt in there thats a 1/2 longer than normal and put a locknut on the backside.
Edited by PelvicThruster, April 12, 2016 - 11:31 AM.
  • toten
Posted April 12, 2016 - 07:14 AM
I'd go with a longer bolt and nut (preferably nylock) if there's space for it. If there isn't, I prefer Timesert to Helicoil, but either will work.
When it comes to bolts into aluminum threads, it's important to not overtighten. You're far better off torquing it a little light with loctite than cranking on it so it won't come out without loctite... of course, a torque wrench and proper torque AND loctite is the best option (unless you've calibrated your wrist that well).
  • problem_child
Posted April 15, 2016 - 09:42 AM
I'd get a new bolt and run a tap through it before heli coiling or going up a size
Edited by problem_child, April 15, 2016 - 09:43 AM.
  • shredmasterz
Posted April 17, 2016 - 12:00 PM
You can try the new bolt and tap idea but I think it is wishful thinking because the aluminum is likely stripped since it is much softer than the steel bolt.  I agree a Timesert is stronger than a Helicoil, but I would use whichever requires you to use the smallest hole size because the frame boss has limited material.  Another option could be to run a longer bolt and put a nut on the back.
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • Hot  33 replies
  • Hot  491 replies
