Replacing Chain and Sprockets
7 replies to this topic
  • Regalman
Posted April 06, 2016 - 04:43 AM
So, I have 2009 WR450 and it and the owners manual is at the cabin.  I want to purchase a new chain and sprockets.  I did some searching, but wasn't sure what my gearing, chain size and number of links is stock.  With the mix of riding I do, I'm fine with the stock setup.
Thanks in advance.
  • stevethe
Posted April 06, 2016 - 04:59 AM
Usually you can punch bike type in Rocky Mountain atv and they will get you what fits. But what you should get is a 520 X-ring chain 13 tooth sprocket and a 50 tooth on the rear. Most people just buy a 120 link chain and cut it to fit.
  • Krannie McKranface
Posted April 06, 2016 - 05:47 AM
^ yes if you buy a 120 it's cheaper than getting it cut to fit for you.
Recommended: JT sprockets
                           Sun Sprockets
                           Sunline Sprockets
                           DID VT-2 chain (premium X ring chain) < lasts hundreds of hours....
Skip the aluminum stuff......
  • Regalman
Posted April 06, 2016 - 07:19 AM
Thanks guys.
Just in case I can find one cheap, what is the correct number of links?
  • WR-Josh
Posted April 06, 2016 - 07:36 AM
114 according to manual  (113+joint)
WR450F 09
  • Arctic Pride
Posted April 06, 2016 - 08:09 AM
your sprocket should be stamped, if you bought the bike used it may have been changed by the PO
  • 2strokeYardSale
Posted April 06, 2016 - 09:36 AM
I just did my 2007 chain and sprockets, 13-50, replaced with 14-50 and 116 link chain.
  • Regalman
Posted April 07, 2016 - 06:37 AM
Thanks everyone.  I did buy my bike new, but it and the manual are 100 miles away from home.
