carb issues
4 replies to this topic
  • Hypheriox
Posted April 04, 2016 - 05:50 PM
I have a 2003 WR 450 and its having a bit of an issue right now. When the choke is pulled out, it will run/idle just like it is supposed to. If i close the choke, I have to bring up the idle on it and it is a bit rough. Could this just mean I need a bigger jet for air. I also just completely tore apart the carb and cleaned it so i know thats not the problem. If possible list jet size recommendations for certain altitudes.
  • stevethe
Posted April 04, 2016 - 05:59 PM
Sounds to me like a partially plugged pilot jet. They are very hard to clean. You should replace it with a new one first.
  • 450crazy
Posted April 05, 2016 - 04:14 AM
A good bet is to take the carb somewhere they can put it in a sonic cleaner. It will most likely clean out the small passages in the carb. I had a 01 wr426 and had the same problem. The sonic cleaning fixed her right up and still running strong. Good luck hope this helps.
  • ttreewalkerr
Posted April 05, 2016 - 04:59 AM
Small guitar string works on all the passages.
  • Krannie McKranface
Posted April 05, 2016 - 05:02 AM
Put in a new pilot jet, but before you install it, ream the passage above it with #15 fishing line and lots of spray brake cleaner
