Dr D Full Pipe Flange ?
4 replies to this topic
  • summitboy
Posted April 03, 2016 - 11:00 AM
I have a Dr D full pipe for my 2015 YZ450.  Do i use the stock gasket ?  It seems like the pipe and flange are not flush like the stocker.  The outer flange seems to sit off the head surface.  The center pipe is flush and tight.  So there is a little gap on the outer flange.  Thoughts, ideas or suggestions ?  Thanks
  • summitboy
Posted April 03, 2016 - 06:31 PM
Really no one has a DR D Racing pipe ?
  • Drenmaster
Posted April 03, 2016 - 10:01 PM
Had the same issue. This is a reply from the guy i bought the pipe from. I am pretty sure i used the stock gasket.
"Use wd-40 and leave all the mounts loose and start at the flange it needs to sit flush. Then work the head pipe and muffler, you just keep moving it till it wont move anymore then tighten it up. Its hard the first 2 times then you figure it out. It really only fits one way. The FMF is just like it. You need to lube up that flange to get it to move before you tighten it. "
Edited by Drenmaster, April 03, 2016 - 10:03 PM.
  • summitboy
Posted April 04, 2016 - 05:15 AM
I dont have a problem with the fit. What im saying is the pipe and flange are not flush when holding in hand. So when installing the inner pipe contacts gasket and flange doesnt actually contact gasket.
  • Costa Rican YZ450F
Posted April 04, 2016 - 12:52 PM
I have a DRD full as well on my '16 it's a little of pain to fully install in my opinion. I checked the instructions for you, said you can use the stock gasket if not damaged. I used the stock one, I've had no problems with mine here are pics on how sits with the flange.
Edited by Costa Rican YZ450F, April 04, 2016 - 12:53 PM.
  • Hot  28 replies
  • On January 15, 2017
  • Hot  36 replies
  • 0 replies
  • Hot  30 replies
