Muffler/Header rubber joiner..thingy
1 reply to this topic
  • Brettv
Posted March 08, 2004 - 11:44 PM
Hi i have a wrf400 99, i only bought the bike a week ago, never ridden it, when i start it its ok, but if i rev it up, comong down off the revs it seems to be popping a bit,
The section where the muffler joins the header pipe is not sealed there is exhaust gases coming out a little bit, if i seal it will it fix my problem?
i got quoted about $100 for just the rubber part!!!!!!!
im in melbourne australia
what do u guys think?
  • R_Little
Posted March 09, 2004 - 05:57 AM
Yes, Exhaust leakes will cause popping.
If you have a stock pipe and header, then there shoulg be a sealing bushing between the header and the muffler. If there is none in there now, then the muffler pipe must be smashed down a bit because this is a big seal that belongs there.
The seal cost me about $6 in the U.S.
If you have an aftermarket pipe then there may be no seal required. In any case there should be no leakage at that joint.
Good luck
Good luck
