Help! 2013 WR450 wont start
10 replies to this topic
  • Dbeeman1
Posted March 31, 2016 - 06:25 PM
I have a 2013 WR450 that will not start. I have replaced the fuel injector, and the fuel pump and swapped the ECU. It doesn't seem to be be getting fuel. If I spray starter fluid into the airbox while cranking over it fires right up but only while spraying. I pulled out the injector while cranking over and it is shooting fuel. This has me scratching my head. Anyone have any ideas
  • Krannie McKranface
Posted March 31, 2016 - 06:27 PM
Is it squirting fuel or misting fuel ?
  • Dbeeman1
Posted March 31, 2016 - 06:30 PM
I don't think I would call it a mist.
  • Pinepig
Posted March 31, 2016 - 08:32 PM
Is it throwing a check engine light?
My buddy was having problems with his and with the diagnostic tool it worked out the MAP was the problem.
We traced it down to a busted wire in the harness pretty quickly.
  • Dbeeman1
Posted March 31, 2016 - 08:36 PM
No check engine light and throwing no codes
  • Pinepig
Posted March 31, 2016 - 08:51 PM
If you think it's not getting fuel and a spray from starting fluid makes it run but then when you pull the injector and test it, it sprays.   My next check would be continuity of the wires running to the injector while wiggling the damn things around to see if you have a break in a wire which is only making contact with the harness in certain positions.
You are getting the priming pulse when you power up and it sprays again when using the button or kicking,  correct?
  • Dbeeman1
Posted April 01, 2016 - 06:01 AM
not sure what a priming pulse is. It sprays with a pulse pattern while hitting the button.
  • Pinepig
Posted April 01, 2016 - 07:30 AM
When you first hit the power button to turn it on it will pulse the injector to spray some fresh fuel in before you hit the start button.
When you first push the power button you can hear the fuel pump build pressure,  correct?
  • Dbeeman1
Posted April 01, 2016 - 11:39 AM
Yes when I hit the power button you hear the pump run for a couple seconds but when I had the injector out no fuel come out during that priming. Fuel only came out while cranking
  • Pinepig
Posted April 01, 2016 - 02:14 PM
Do you have the factory service manual?
It has a bunch of specs to ohm out and check various sensors without just throwing parts at it.    I'd still suspect the wiring to the injector if it passes the test while looking at it then when you move it to put it back in you seem to think you are getting no fuel.
  • 450crazy
Posted April 05, 2016 - 04:51 AM
Has there been any progress with getting your bike going?
