  • Instagram
Related Garage
Yamaha YZ450F (2010)
Owner: Dmeiborg
Added on January 19, 2017
Related Reviews
Yamaha YZ450F 2013
Last review by Ride_Flip_Repeat
Yamaha YZ450F 2004
Last review by 1trackmind
Yamaha YZ450F 2015
Last review by Jason Enger
Last review by Tommyk_55
Yamaha YZ450F 2009
Last review by 09_Yz_450f_14skillings
What did you do to your YZ450FX today?
452 replies to this topic
  • RMK800
Posted May 25, 2016 - 08:56 AM
Added some EVO Pro taper Windham Bend handlebars. Renthal Kevlar grips. Love these grips.
Edited by RMK800, May 25, 2016 - 08:57 AM.
  • hondaman331, RockerYZWR and Toa84 like this
  • Like This
  • hondaman331
    Hasta la vista
Posted May 25, 2016 - 03:34 PM
pretty flat bars
  • RMK800
Posted May 25, 2016 - 03:36 PM
pretty flat bars
What do you mean by flat?
  • hondaman331
    Hasta la vista
Posted May 25, 2016 - 04:01 PM
straight almost on pullback and low rise.
  • RMK800
Posted May 25, 2016 - 04:39 PM
There is a difference in rise and that expected with taller bar, but the Windham actually has more sweep then then YZ high bend. Their actually pretty close to stock feeling except for height, which I like the stock profile.
Edited by RMK800, May 25, 2016 - 04:45 PM.
  • cowboyona426
Posted May 26, 2016 - 05:55 AM
I meant to get some more comparison pics of the stock bars to a set of Windham's, I'll try to remember to do that tonight.
  • blbills
Posted May 27, 2016 - 06:08 PM
Went Mudding...  Don't ask how long it took to clean up ;-)
  • vossman23
Posted May 28, 2016 - 05:15 AM
Excellent, how did it ride? You probably got 50 pounds of mud on there.
  • BGoyins
Posted May 28, 2016 - 05:57 AM
I heard KTM's carry about 12 pounds less mud.
  • cowboyona426, MidlifeCrisisGuy, Jeffrey Dyment and 1 other like this
  • Like This
  • Jeffrey Dyment
Posted May 28, 2016 - 11:50 PM
Rode the hell out of my FX at North Humberland trails.  The hand numbness is finally going away!
God I love this bike...
  • blbills
Posted June 04, 2016 - 02:16 PM
Tested out the range...  74.8 miles of mixed single track, fire roads, log hopping, etc... until empty.
  • cowboyona426, RMK800 and TwentyFive20 like this
  • Like This
  • cowboyona426
Posted June 04, 2016 - 06:20 PM
Damn that's impressive!  No need for a larger tank with a range like that.
I finished up the first oil change today and checked suspension settings.  On that note, what is everyone running for clicker and sag settings on these bikes?
  • hondaman331
    Hasta la vista
Posted June 05, 2016 - 03:23 AM
if it's a 16, I found forks 5mm up, sag at 100mm and 2 clicks out on fork compression and add a half turn out on high speed. This is the 5th combo I have run and it is spectacular. Too much sag by a few mm and the front pushes, if you don't move the forks at least 3mm then the front pushes. This bike is very touchy and the sag and fork height change the bike drastically with small changes.
  • NW_drZ and TwentyFive20 like this
  • Like This
  • RMK800
Posted June 05, 2016 - 06:00 AM
The FX has 22mm forks, do you still recommend the 5mm up?
  • NW_drZ
Posted June 05, 2016 - 09:20 AM
This is almost exactly what I'm running on my 250FX.. Forks up 3-5mm, 2 clicks out on compression, 1 on rebound, and half out on high speed.
  • yz426rdr and hondaman331 like this
  • Like This
  • hondaman331
    Hasta la vista
Posted June 05, 2016 - 10:15 AM
with that setup I don't even think about the bike....it just does it!
  • hondaman331
    Hasta la vista
Posted June 05, 2016 - 10:17 AM
I'm not recommending anything....if the bike pushes, try it, if it don't then don't. I think with a 22mm offset I would keep the sag at 100mm and then adjust with that first, put forks up last
  • blbills
Posted June 05, 2016 - 12:57 PM
That's just about my setup as well.  I played with raising the forks but for me it increased the head wabble at high speed so I dropped them back down.
  • hondaman331
    Hasta la vista
Posted June 05, 2016 - 04:04 PM
is it the yz450f or yz450fx? On the 450f it seems like the fork height is situational but sag needs to be at the recommended range. I like having the forks up and don't seem to have any negatives except if it's really hardpack....
  • jwilson32
Posted June 05, 2016 - 09:59 PM
Is that 2 clicks out from the middle setting?
Is anyone that weighs around 255lbs able to get 100mm of race sag with a decent static sag number? I have a 6.8 shock spring and 5.4 fork springs. To get 100mm of race sag I'm at around 14mm of static sag which I feel is not enough. But I don't think there's a higher rate spring. I'm running around 110mm with 25mm or so of static sag. Bike pushes a bit which is why I'd like to be closer to 100mm.
Linkage was greased when I got the bike home and there's no binding...
  • Hot  30 replies
  • Hot  38 replies
  • Hot  36 replies
  • Hot  47 replies
  • Hot  28 replies
