  • Instagram
Related Garage
Yamaha YZ450F (2017)
Owner: Tommyk_55
Added on January 15, 2017
Related Reviews
Last review by Tommyk_55
Yamaha YZ450F 2015
Last review by Jason Enger
Yamaha YZ450F 2011
Last review by Le_Racer
Yamaha YZ450F 2009
Last review by 09_Yz_450f_14skillings
Yamaha YZ450F 2016
Last review by YZJeffro64
What did you do to your YZ450FX today?
454 replies to this topic
  • TheKillaCam
Posted May 02, 2016 - 12:57 PM
Add a gytr brake lever.
How do you like the lever? I'm considering buying both the clutch and brake levers just like yours.
  • RMK800
Posted May 02, 2016 - 02:10 PM
I haven't taken a ride with them yet.  The brake feels good.   I accidentally ordered the wrong clutch,  What I like about viewing the clutch is that you can set the width.  So I can move it back and forth. The stock clutch does not have that feature.  I assumed the YZ450 was the same and its not.  Is yours a yz or fx?  Because I would send you the clutch before sending it back as a return if yours is a YZ.
  • TheKillaCam
Posted May 02, 2016 - 02:23 PM
Mine is a 2016 yz. PM me.
  • RMK800
Posted May 02, 2016 - 03:27 PM
The Windham bend is closer to 1 1/4" taller than stock, and are also bent so that the hand position is moved forward of stock by at least that amount when the bars are adjusted so that the tops are flat.  There's no problem with any of the cables.  The Windham bend is excellent for any YZ/FX/WR.
Hey GreyRacer, when I look at Protaper web site it lists the YZ High specs, is that the same specs as would be stock?  I have read conflicting info on this.  Do you know the exact specs on stock handle bars?  Thanks
Posted May 03, 2016 - 05:37 AM
I don't know for certain.  I know the YZ High listing you mention, but I'm not sure those duplicate stock bars.
  • RMK800
Posted May 03, 2016 - 06:54 AM
PM sent
  • keeseckb
Posted May 04, 2016 - 07:28 PM
So far I have replaced the stock air filter with a K&N with outerwear and replaced the tubes with heavy duty ones. Next couple of days I'll get my Cycra Series One handguards with mongo mount, FMF 4.1 aluminum, Renthal grips and Decal Works number plate backgrounds installed. I'll post some pics as I go and maybe a before and after video of the stock exhaust vs FMF.
Love this bike!!
  • stevethe
Posted May 05, 2016 - 06:50 AM
Love this bike!!
You won't likely find too many fans of using K & N filters as they let fine dirt into the motor if it's used as a dirt bike.
Posted May 05, 2016 - 07:02 AM
K&N gauze filters, when oiled correctly, filter better than foam and with less resistance to air flow, but only for a little while.
Because of the lack of cross sectional depth in the filter media, the load up sooner than foam elements, and once loaded. they start passing dirt through.  They're fine on a street bike, or if you're always the guy in front, or if there just never is any real dust to deal with, but in most real world conditions, they won't last one whole ride day without needing to be cleaned.
  • keeseckb
Posted May 05, 2016 - 08:10 AM
Surprised to hear that about K&N filters. I figured since they are used in GNCC racing and Baja that they would be up to snuff.
Posted May 05, 2016 - 08:22 AM
Well, I can't say that I agree with the practice.
Consider how both the foam and gauze elements actually work.  The media itself is too coarsely "woven" in either case to do much about filtering the finer grit they encounter, so a sticky oil is applied to it.  The idea is that there being no straight line path through the media, the dirt will run into some part of it as it attempts to pass through, and will get stuck in the oil.  The filter, then, can only function properly until the oil on the element gets saturated with dust, after which new pieces of dirt will fail to be captured, and pass through.  Because of the much thinner media cross section in gauze filters, they have a reduced capacity for collecting and holding dust, and that capacity can be exceeded more rapidly than foam at any degree of dust exposure.
By actual test, gauze filters fail to stop dust for as long as foam does, even though they work a bit better before they load up.
  • keeseckb
Posted May 10, 2016 - 12:55 PM
Got my number plate backgrounds from Decal Works, FMF 4.1 slip on and cycra handguards installed. Getting close to being complete. Here is a crappy pic in the garage right after I got the exhaust and graphics on.
  • Frank Swindell
Posted May 10, 2016 - 04:21 PM
Here is a few things I added to my 2016 450fx, FMF 4.1 exhaust only, GYTR Hand guards.Electric Fan, Radiator guards, ODI Emig lock on grips, Light Speed protective electrical fuse box cover, Nitho case saver and Decal Works graphics. After photo was taken suspension was done by Pro Action. just a spring change 4.9 front and 6.1 in rear just to get the correct  sag numbers.
Edited by Frank Swindell, May 10, 2016 - 04:28 PM.
  • vossman23
Posted May 12, 2016 - 05:58 AM
That red looks really good against the blue, well done.
  • hondaman331
    Hasta la vista
Posted May 21, 2016 - 03:30 AM
I bought the Yamaha swingarm sticker that comes on the yellow but not blue....this bike I will race stock, no need for any mods whatsoever.
  • Albu862
Posted May 21, 2016 - 07:28 AM
Started with a scrub down, mounted some fresh knobbies and parked it in the apartment until the wet weather passes. ImageUploadedByThumper Talk1463844463.654233.jpg
  • TheKillaCam
Posted May 21, 2016 - 07:30 AM
Where did you buy the swing arm decal?
  • hondaman331
    Hasta la vista
Posted May 21, 2016 - 10:37 AM
local shop, it's an oem part.
  • TN Dirt Rider
Posted May 21, 2016 - 02:35 PM
Revalved the forks, previous owner had them super stiff.  Going to try them out tomorrow in the woods.
Also, drilled out relief hole in the free pistons since they weren't cracked yet.
  • cowboyona426
Posted May 22, 2016 - 09:00 AM
Installed GYTR radiator cages on the beast yesterday, was hoping for better fit and finish from a Yamaha supplied part but happy to have some protection for the delicate radiators.
  • Hot  47 replies
  • Hot  36 replies
  • Hot  50 replies
