  • Instagram
Related Reviews
Yamaha YZ450F 2006
Last review by Yzrider1023
Yamaha YZ450F 2012
Last review by Jason Heinrich
Yamaha YZ450F 2014
Last review by Gode
Yamaha YZ450F 2004
Last review by 1trackmind
Yamaha YZ450F 2013
Last review by Ride_Flip_Repeat
Related Garage
Yamaha YZ450F (2017)
Owner: Tommyk_55
Added on January 15, 2017
What did you do to your YZ450FX today?
440 replies to this topic
  • RMK800
Posted September 22, 2016 - 03:16 PM
I haven't had an vibration issues or clutch noise. Have over 60hrs, but I'll try to pay more attention on my next ride.
  • mxrider4life847
Posted September 22, 2016 - 05:35 PM
The only strange noise I've heard was after a boil over, heard a loud ticking noise which sounded like a valve. It showed up very obvious after the bike warmed up... when I pulled my radiator off to straighten it, I noticed the coolant level was fairly low. Put rad back on and serviced, no more noise. And hasn't done it since.
Edited by mxrider4life847, September 22, 2016 - 05:36 PM.
  • Krannie McKranface
Posted September 22, 2016 - 08:09 PM
Replaced the stock seals with SKV
Lowered the oild height from 315 to 305
Have not tried it out yet.
  • RichDawson
Posted September 23, 2016 - 02:32 PM
Anybody got their eyeballs on a 2017 450FX yet? I'm (not very patiently), awaiting the arrival of one and am very stoked.i already have Rad Guards, rotor guards, skid plate, swingarm guard, bib mousse inserts, hand guards, tall seat, big tank, risers, new front tire, chainguid, frame guards, number plate backgrounds...just need a bike to put it all on.
  • cubera
Posted September 23, 2016 - 05:19 PM
50 mile solo ride. Motor is bone stock with linear mapping FMF Megabomb. It rips.
Posted September 23, 2016 - 05:58 PM
Pretty amazing how these bikes are so neutral in handling and so smooth yet snappy in the power, huh....
I am still impressed.
Makes my fully built and set-up 450X feel like a muscle car with flat tires....
  • cubera
Posted September 23, 2016 - 06:39 PM
Bill, no doubt Yamaha got it right with the 450FX. :ride:  :thumbsup:
  • WiscoDisco
Posted September 24, 2016 - 09:35 AM
I got things in the mail. Handlebars and grips went on for tomorrows hare scramble. Rest goes on tomorrow night! Pics to come...
  • jwilson32
Posted September 24, 2016 - 01:28 PM
No noise in the clutch area on mine. I'm really digging this bike!
One issue is the brake pedal tip is a little week. I talked to Grant Baylor's mechanic Cory MacDonald a couple weeks ago at the enduro and they're having the same issue. Anyone found a good replacement tip? I ordered this one. It's a little longer although that may be a good thing as I have a size 13 boot and hit the shifter accidentally a lot. Ill have to bolt it on as the OEM is riveted on. I'll report back once I put some rides on it.
https://www.rockymou...acement-Toe-Tip
Posted September 24, 2016 - 02:35 PM
I am making one out of thick sheet steel, to bolt to the side of the pedal, and the cleats will Fastway allen-spikes.
  • NorCal
Posted September 27, 2016 - 09:16 AM
What makes you so excited about the 2017? Isn't it just a 16 with black rims and the kickstarter removed?
  • jwilson32
Posted September 27, 2016 - 09:26 PM
I just wanted to confirm that there's not a separate area for transmission fluid. I still can't believe this bike only takes .69 liters.
Posted September 28, 2016 - 07:33 AM
All the same oil volume.  The wet sump design just doesn't allow more oil storage than that.
  • SurvivorMan
Posted September 28, 2016 - 11:06 AM
What are you guys running for a good head light setup?  Looking at stock WR, but I'm sure aftermarket has better options.
As for gearing, I found the bike to be geared too slow from the factory...too much engine breaking.  I sped things up to a 13/48 and really like that...so 14/51 once I need to order new sprockets.
  • RMK800
Posted September 28, 2016 - 01:54 PM
Ya gearing is all personal preference. I ride very long downhill and tighter single track and like the lower gearing and engine breaking. I don't mind a little bit of top end loss.
  • stevenfallover
Posted September 28, 2016 - 05:20 PM
I put on the Baja Design XL Pro for a headlight, but we ride at night a lot.
https://www.bajadesi...light-shell.asp
Edited by stevenfallover, September 28, 2016 - 05:32 PM.
  • blbills
Posted September 28, 2016 - 08:11 PM
Decisions decisions...  I've got the leaky fork syndrome and I'm trying to debate what to do.  I've heard they made some improvements to the fork for 2017 so I compared the part fiches and it looks like they changed two things.  1) a revised oil seal, and 2) they added what they call a scraper between the oil seal and the dust seal.
Should I get these items and do a rebuild or transition to something aftermarket like the SKF's?  I don't understand what makes these so different from the 450F forks from a seal perspective?
  • SurvivorMan
Posted September 29, 2016 - 11:21 AM
Looks like a great setup, but I'm sure I can find something that works great for around $100.  I have a Trail Tech HID helmet light that works amazing for aggressive night riding, the front headlight for me is only necessary to get me out of a late ride.
Did you wire it to the battery directly with a switch or into the wiring harness somewhere?
  • stevenfallover
Posted September 29, 2016 - 11:24 AM
Directly to the battery. It draws 40 watts.
  • cowboyona426
Posted September 29, 2016 - 01:53 PM
I'll be setting mine up with a 6" LED light bar and tying into factory wiring, with a switch to turn the light off and on as desired.
  • On January 15, 2017
  • 0 replies
  • Hot  47 replies
  • Hot  113 replies
