Anyone know stock main air jet size on 04?
6 replies to this topic
  • sjwr450
Posted March 08, 2004 - 04:27 PM
  • DeltaT
Posted March 08, 2004 - 06:11 PM
Manual says #165 for US, #160 for others. I'm putting in the JD kit this week, and will tell you what I found there.
Jim
PS Met WRSteve at HH. He said you might be interested in riding. I'm in Santa Clara.
  • mtrablue
Posted March 08, 2004 - 06:24 PM
it should be in your manual. the maintenance specs near the front lists the carb stuff including all jets. the '03 shows the main air jet as a 2.0. not sure what that means or where it's even located in the carb.
  • Indy_WR450
Posted March 08, 2004 - 06:28 PM
200 is stock and not adjustable! Fixed main air jet size on 03's and 04's. :)
  • PBDBLUE
There actually is no main air jet in the '04 carb. It has a 2.0mm opening cast in the housing but no jet like the earlier carbs.
  • DeltaT
Posted March 08, 2004 - 06:29 PM
Sorry, I thought you meant Main Jet, until I saw your YZ post. The 'Main Air Jet' on the 04 is 2.0 for all countries. Pg. 2-8 in manual has all carb specs.
Jim
  • Indy_WR450
Posted March 08, 2004 - 06:41 PM
2.0 mm is 200 main air jet. It is fixed on these bikes but it does exist! :)
