Rear brake problem
15 replies to this topic
  • james25
Posted March 27, 2016 - 04:05 PM
Hi boys, need help. My rear brake keeps sticking. Cleaned the return port, new brake line, new caliper internals. Bike will even sieze itself if left on stand. Wtf
HELP HELP!!!
  • Jimmy boy
Posted March 27, 2016 - 05:10 PM
HELP HELP!!!
rebuild the caliper .
Check that the fluid is returning back to the master cylinder .
  • james25
Posted March 27, 2016 - 05:17 PM
Done all that
Only had this problem since replacing the pads. Now pads are absolutely rooted
  • Krannie McKranface
Posted March 27, 2016 - 05:33 PM
One of the pins is probably bent or corroded.
Replace them.
  • james25
Posted March 27, 2016 - 09:01 PM
But that doesn't explain why is just does it on its own without even using the bike at all
  • Markin
Posted March 28, 2016 - 02:07 AM
May be fluid level is too high and you have pressure in system even with brake pedal not pushed. This situation occurs when brake level was set before before replacing old thin pads by new (thicker).
  • Jimmy boy
Posted March 28, 2016 - 05:46 AM
Could be the new pads aren't fitting correctly and causing bind. Stick the old pads back in and see if problem is still there.
  • james25
Posted March 28, 2016 - 11:15 AM
I took it all apart today and cleaned and greased it all, I did happen to notice a notch in the pin.
Posted March 28, 2016 - 01:19 PM
If the hydralic system is overfilled, the brake pads will eventually make firm contact with the rotor, and if hot enough, it can lock up.
  • james25
Posted March 28, 2016 - 05:35 PM
Happened few times while riding, the wheel completely locks up. Rotor glowing. Might try new pin take some fluid out and set of new pads. Thanks for your help
Posted March 28, 2016 - 06:45 PM
Just open the top, spill out a little, and close it back up and try it.
  • james25
Posted March 29, 2016 - 02:28 PM
Put new pads in yesterday and couldn't even push the piston back in. Also put new pads in the front. Pistons went in easy. Think it's time for another MC
  • Jimmy boy
Posted March 29, 2016 - 04:02 PM
crack the bleeder and try pushing it in . The piston may be sticking.
  • james25
Posted March 29, 2016 - 04:25 PM
Yes that did work
  • Jimmy boy
Posted March 29, 2016 - 04:32 PM
The return fluid port sounds plugged. Take the master cyl top off and put fluid through the caliper bleeder. It will put fluid in master, so take some fluid out.
  • james25
Posted April 09, 2016 - 08:02 PM
Put another mc in, big difference. Really easy to prime. Havnt riden it yet though. Hopefully that has fixed the problem
