Make it stop!
21 replies to this topic
  • allryder
Posted March 26, 2016 - 07:20 AM
So I've been having front brake problems (06 yz450f). There is a lot of lever play before the brake starts to engage. My brother has an 05 yz250 and his front brake feels awesome and engages right away, no play in the lever at all. There is about 1/2 to 3/4 inch of play in the lever before it starts to engage. I have completely flushed the fluid and that didn't work. Then I rebuilt the front master cylinder, any idea what it could be?
  • bodge
Posted March 26, 2016 - 07:24 AM
I would start by bleeding it quite well. It sounds like there is air in the line. Have you tried to back bleed it?
  • little_wing
Posted March 26, 2016 - 07:28 AM
back bleed for the win
  • cjjeepercreeper
Posted March 26, 2016 - 07:34 AM
OK, everyone says this.  In theory, it is a fantastic idea.  But I want to know, how many of you advocating this have actually tried it:confused:   It is messy, yes I've tried it a few times and have always ended up bleeding the traditional way with great success.
Be honest, who has done this without making a mess? :thinking:
  • DEMI
Posted March 26, 2016 - 07:47 AM
Backbleeding for the win X2
It works and quick too. Not very messy if, pause and look, etc.
Edited by DEMI, March 26, 2016 - 07:48 AM.
  • cjjeepercreeper
Posted March 26, 2016 - 07:53 AM
Not VERY Messy?  LOL, it is a bigger mess than the traditional way no matter what you do.  The old fashioned way is ZERO mess, and yes it does work. ;)
  • HappyAndy
Posted March 26, 2016 - 08:14 AM
Reverse bleeding brakes is easy with the right tools.
I do it all the time on industrial vehicles that I work on professialy.
I have an oil squirt bottle from HF and some various sized clear hoses.
Also, the OP's problem could be from a failing brake hose with a weak spot.
Edited by HappyAndy, March 26, 2016 - 08:35 AM.
  • DEMI
Posted March 26, 2016 - 08:29 AM
You're doing it wrong!! What's the old way? Gravity and pumping the lever... if you are retired then that way is an option...lol.
  • cjjeepercreeper
Posted March 26, 2016 - 08:48 AM
A few months ago I rebuilt the front caliper on my bike.  Bleeding and completely purging the system took less than 15 minutes doing it the old fashioned way.  And there was zero mess and no air in the line. ;)
  • DEMI
Posted March 26, 2016 - 08:55 AM
Evidently it is your way or the wrong way, so here's your pat on the back.
  • cjjeepercreeper
Posted March 26, 2016 - 09:08 AM
Thank you. :)
As I mentioned earlier, I think a lot of folks have heard about back bleeding, so they follow the herd and advocate it without actually trying it.
  • DEMI
Posted March 26, 2016 - 09:27 AM
I have a feeling you will argue for the sake of arguing, don't need a pissing contest with you, so have a great weekend.
  • filterx
Posted March 26, 2016 - 09:35 AM
To the OP - Did you ever NOT have the free play?
  • allryder
Posted March 26, 2016 - 09:56 AM
So how exactly do you back bleed it
  • allryder
Posted March 26, 2016 - 06:50 PM
I just purchased it about a month ago so I've felt it as long as I've owned it
  • bodge
Posted March 28, 2016 - 04:05 PM
OK, everyone says this. In theory, it is a fantastic idea. But I want to know, how many of you advocating this have actually tried it? :confused: It is messy, yes I've tried it a few times and have always ended up bleeding the traditional way with great success.
I've back bled a few ktm clutches and the front brake on my cr250. It can be messy but I'm usually expecting that so no worries. Just have to place rags where needed. Edit: I use a 60cc luer lock syringe and some carb vent hose I had laying around. Works ok.
Edited by bodge, March 28, 2016 - 04:08 PM.
Posted March 28, 2016 - 05:00 PM
I gravity bleed them.  Works perfectly well.  There's one glitch regardless of the method, and that is that there is a big wide spot for a bubble to take up lodging right at the banjo bolt at the master cylinder.  That bubble can usually be "tickled" out into the reservoir by working the lever just a couple MM at a time.
  • cesper
Posted March 29, 2016 - 09:31 PM
Does it feel spongy ALL the time, or just when you're on the trail and moving? If your rotor is bent, it will push the pistons back in the caliper a little when the high spot of the rotor passes through. This will cause excess travel in the lever, although usually it'll pump out quickly. If your problem is all the time, even when still, then ignore this.
  • allryder
Posted March 30, 2016 - 04:07 AM
All the time, it was spongy before I rebuilt the master cylinder, now it still has play in the lever but after the short amount of play, the lever is stiff.
  • cowboyona426
Posted March 30, 2016 - 07:17 AM
That's a good trick.  I also like to get the lever as firm as I can get it, then zip-tie the lever to the bars at least overnight to help coax any additional tiny air bubbles out.
