Flywheel Installation, help needed!
6 replies to this topic
  • Gunner_V
Posted March 19, 2002 - 01:03 AM
Does anyone know the best way to hold onto your flywheel when you are taking your flywheel nut off without having to buy a special tool? I tried leaving the bike in gear and blocking the wheel from spinning, but it didn’t work. Help! I have a Ty Racing 10 oz. Flywheel weight sitting in my toolbox because I can’t install it!
  • Mark_UK
Posted March 19, 2002 - 03:26 AM
stick a screw driver in and jam the counter balence wieght
  • Tommy_Gun
Posted March 19, 2002 - 05:45 AM
Even though you have a Ty Davis flywheel, get one of these engine lockup tools from Steahly Off-Road at: http://www.steahlyof...log/tools.shtml
They work excellent.
-Tom
  • mor
Posted March 19, 2002 - 05:56 AM
i used air driven wrench.
  • wylie1
Posted March 19, 2002 - 06:10 AM
I used a pneumatic impact to remove the flywheel nut. To get it back on I bought a special oil filter wrench from Napa auto parts for $6.00. The oil filter wrench looks like a piece of nylon strap with a square piece of metal tubing hooked on the side of it. I put it around the entire flywheel to hold the flywheel in place and was able to torque the flywheel to specification. Hope this helps.
James
[ March 19, 2002: Message edited by: wylie1 ]
  • wylie1
Posted March 19, 2002 - 06:23 AM
Here is the Napa tool.
http://www.napaonlin...6&usrcommgrpid=
and motion pro has a really good one.
http://www.motionpro...icetools_3.html
  • yankee
Posted March 21, 2002 - 03:52 AM
I use a motion pro clutch holding tool. I got it for $30 from the local dealer. You can use this tool for the clutch basket, primary gear, flywheel, and front sprocket.
If you have access to an impact wrench you can use that instead.
If you have the right crankcase cover off than you can just stick a small piece of aluminum between the primary and clutch basket gears. This will stop the crank from moving.
[ March 21, 2002: Message edited by: yankee ]
Motocross
  • Hot  491 replies
  • 0 replies
  • Hot  28 replies
