FX Axle blocks
8 replies to this topic
  • BolinJrsPit Crew
Posted March 20, 2016 - 01:29 PM
Went to adjusted my chain and found that I have two different axle blocks. Is this normal? If so what's the trick to adjust it. Left side has 9 notches and right side has 12 and they are not only different in count but different in spacing. Had to eyeball the wheel straight. What gives?
  • Monk
Posted March 20, 2016 - 01:55 PM
One has a lip on it to keep the axel from spinning. I use a sag scale and measure from the center of my wheel axel to the center of my swingarm axel. Dead straight everytime...
  • BolinJrsPit Crew
Posted March 20, 2016 - 02:52 PM
Good to know thanks. Been counting notches for years.
  • SAthump
Posted March 20, 2016 - 03:01 PM
They are equal from the rear
Last several bikes have all been accurate
Be warned one notch can go from too loose to too tight
  • RMK800
Posted March 20, 2016 - 05:19 PM
They are both equal from the rear. I took these shots before I replaced my sprocket.
  • mobgma
Posted March 20, 2016 - 09:18 PM
I use these.
http://boltmotorcycl...ter-blocks.html
Love them. No more jam nut. 5 years straight.
  • cowboyona426
Posted March 21, 2016 - 07:51 AM
A bit more tedious than your method, but I use a set of calipers and measure from the front edge of the axle block to the swingarm just above or below the jam nut.
Posted March 21, 2016 - 01:12 PM
Potentially inaccurate.  There is no real reason to trust that the seating surface for both jam nuts is precisely equidistant from the swing arm pivot unless you measure it.
  • cowboyona426
Posted March 21, 2016 - 01:33 PM
Potentially yes, but from my experience it's accurate.  In all the years I've done it that way I've never had issues with sprocket wear or any other issues.
  • 10 replies
  • 5 replies
  • 0 replies
  • Hot  36 replies
