The mystery of the disappearing oil
13 replies to this topic
  • Gofres
Posted March 20, 2016 - 03:58 AM
So... my bike is using a lot of oil lately but it's not clear where its going. The bike starts and runs well, pulls hard throughout the rev range and doesn't smoke.
But its using around 300-400ml of oil every ride (around 4-5 hours) and the oil turns black after a fresh change and new filter within about an hour of riding. There's also some black soot deposits around the exhaust.
I'm guessing all signs are pointing to worn piston rings but is there anything else I could look for or something I might be totally missing?
Thanks in advance
  • stevethe
Posted March 20, 2016 - 04:57 AM
Are you riding a Bultaco and mixing the oil in your gas?
  • Krannie McKranface
Posted March 20, 2016 - 06:35 AM
Soot means oil
You are burning it.
Probably valve guides/seals
  • mlatour
Posted March 20, 2016 - 07:58 AM
Any sign of oil leaking out the crankcase vent as well ?
  • Gofres
Posted March 20, 2016 - 08:52 AM
Oil in gas?? It's a 4 stroke! unless I've been doing something very wrong all this time lol.
  • Gofres
Posted March 20, 2016 - 08:54 AM
Soot means oil
You are burning it.
Ok thanks, I'll take a look at the seals too. I bought the bike with very little history and I've put around 60-70 hours on it so far so I guess it's probably worth changing the piston and rings right?
  • Gofres
Posted March 20, 2016 - 08:57 AM
no signs of any leaks elsewhere.... just pulled the plug and its heavily covered in carbon! As Krannie said, its gotta be burning it. It's just bizarre theres no smoke, just a tiny puff on start up which I assumed was moisture.
  • stevethe
Posted March 20, 2016 - 06:18 PM
We can't be sure what model you have? But make sure your not overfilling it and loosing oil out the beather pipe.
  • Gofres
Posted March 20, 2016 - 10:57 PM
Sorry it's a 2004 wr450fs. No signs of anything coming from breathers either.
  • GuyGraham
Posted March 21, 2016 - 10:55 PM
It doesnt need to burn much which doesnt show up as smoke to show up as a loss
If its smoking then it really burning it fast
Mine used to burn 150/200ml in 2hrs but didnt smoke at all. New rings at 400hrs fixed it
Worn valve seals usually causes smoke on startup as the oil seeps past whilst sat overnight
Edited by GuyGraham, March 21, 2016 - 11:09 PM.
  • Gofres
Posted March 23, 2016 - 01:56 PM
Can anyone recommend a top end rebuild kit in the UK? I've only found reasonably priced ones on ebay but all come from the US and when you add the import tax, isn't that great a deal.
I'm mainly looking at Wiseco... any thoughts on if they're OK or totally avoid?
  • stevethe
Posted March 23, 2016 - 02:29 PM
Probably better to go to stock parts.
  • GuyGraham
Posted March 23, 2016 - 11:22 PM
What year bike is it
I have a gen yam 2s2 piston which fits 08 and 09 plus gaskets and rings that is surplus to requirements now
Pm me if your intereseted
  • Gofres
Posted March 25, 2016 - 02:32 AM
Many thanks, it's a 2004 so not sure of fit
