TT official 2016 WR450F mods
87 replies to this topic
  • foggy3061
Posted May 19, 2016 - 06:45 AM
#41
Yamaha's suggested maps for the 2016 WR450F, might be a good starting point for someone.
  • gize
Posted May 19, 2016 - 03:38 PM
#42
Nice, thank you for posting. My dealer did the whole competition kit thing as well as putting on the fmf 4.1 slip on, then tuned it for me. It seems to run great but I'm tempted to get a tuner to see what settings I'm at and try some new just to make sure it's the best for my riding.
  • Ghazzah
Posted May 20, 2016 - 02:28 AM
#43
Mods.
            #26
  • theboondork
Posted May 24, 2016 - 08:03 AM
#44
I just bought a 2016 Yamaha WR450 and I would really like to get a set of plastic body parts that are black. I've looked around the Internet with no luck and have come to the conclusion that no one is making black 2016 plastic body parts yet.
I thought about painting my plastic parts but I've had limited success with paints like Krylon Fusion, and I would like to keep my plastic parts new if possible so I could put them back on if I sell the bike.
The other thing I've considered is buying a plastic part set for a different year and modifying it to fit. I wouldn't mind doing that because I enjoy DIY stuff, but I don't have enough knowledge to know what part set might come close to working. It would even be okay if most of the parts would fit and I could paint a couple of my parts black to complete the set.
I've only been a member of Thumper Talk for a short time but in that short time I have learned that there is more knowledge here than in several other places put together, so if there is a solution to my problem I'm sure it will be found right here. So if anyone has any ideas I will appreciate your thoughts.
                                   PS.  I hope I posted this in the right place.
   theboondork
Edited by theboondork, May 24, 2016 - 08:06 AM.
  • Krannie McKranface
Posted May 24, 2016 - 05:17 PM
#45
   theboondork
Not the right thread
Start your own in this forum
  • foggy3061
Posted June 05, 2016 - 09:27 AM
#46
A copy of the 2016 WR450F workshop/owners manual is available for free download here:
http://www.yamahaown...GC-28199-70.pdf
Edited by foggy3061, June 05, 2016 - 09:27 AM.
  • dezrattbo
Posted June 05, 2016 - 05:44 PM
#47
Hola amigos got this bike 3 wks ago just hit the 400 mi mark, I had a 04 it had around 9k miles finally broke her so I upgraded and what a bike.But I do have a few issues
#1 don't like the air filter intake system the cowling I guess I get water mud & dust in there every ride there is muddy water all the way down to the filter and the foam pieces inside dust magnets.anybody know if or where the air filter gets relocated if I put a Ims 3 g tank on
Thnks and ride on
Posted June 05, 2016 - 08:39 PM
#48
Thnks and ride on
Acerbis makes a better intake/shroud system for the '16.
The IMS 2.9 tank does not relocate anything.
  • finbike
Posted June 08, 2016 - 09:32 AM
#49
Regarding the gytr muffler insert, if you have some welding experiance or know somebody who has. It´s quite easy to reuse the stock insert and fit a larger diameter steel tube. Just cut away the tube from the "plate" and drill a 30mm hole in it. Weld a new larger tube to the plate, 30mm is the largest that fits and a bit larger than the gytr insert I think. So that way you get a better insert, and also cheaper if you got the tools.
  • chelder
Posted June 08, 2016 - 01:39 PM
#50
Got my Acerbis 11l tank all done and it's sweet can't wait to ride it properly, just waiting on the knee the heal up after a reco but took it for a bit of a run around the block and it's all good.ImageUploadedByThumper Talk1465421898.417280.jpg ImageUploadedByThumper Talk1465421922.930001.jpg ImageUploadedByThumper Talk1465421944.146707.jpg
  • stevethe
Posted June 15, 2016 - 03:36 PM
#51
Got my Acerbis 11l tank all done and it's sweet can't wait to ride it properly, just waiting on the knee the heal up after a reco but took it for a bit of a run around the block and it's all good.attachicon.gifImageUploadedByThumper Talk1465421898.417280.jpgattachicon.gifImageUploadedByThumper Talk1465421922.930001.jpgattachicon.gifImageUploadedByThumper Talk1465421944.146707.jpg
Excellent job of putting a 2.9 gallon Acerbis tank made for the YZ in a 2016 WR 450. No bogus radiator shroud gas tank.
I will be trying one on as well. Hopefully the smaller lithium replacement batteries will fit on top of the back section of the tank.
Edited by stevethe, June 16, 2016 - 06:09 AM.
  • foggy3061
Posted June 16, 2016 - 09:03 AM
#52
Sounds like a good time to create a how to guide!
  • chelder
Posted June 16, 2016 - 01:01 PM
#53
The standard lithium ones you generally see won't like the SSB ones etc.... Need to use a superb battery or something like that.
Posted June 16, 2016 - 01:30 PM
#54
Do you have available the model number of the one that you used?
  • chelder
Posted June 16, 2016 - 01:32 PM
#55
Yep, SB12V2600P-AC
Super B
  • stevethe
Posted June 16, 2016 - 04:07 PM
#56
Ha I'm right there. The Shorai is a little too big. A smaller battery would be better or I might have to melt the seat to make it fit.
It looks like I can get the wiring and relays in-between the fender and back bar to the seat.
  • chelder
Posted June 16, 2016 - 04:12 PM
#57
Another thing I looked at that does work but I changed my mind is behind the bash plate at the front of the bike the SSB fits or Shorai is the same as the as the SSB so should fit I run the high GYTR seat so could probably make it work cutting it into the seat of you wanted.
  • stevethe
Posted June 16, 2016 - 04:17 PM
#58
No it looks like you found a very nice thin battery. http://www.super-b.c...//sb12v3200e-ac
I hope I can get one or a similar one in the USA.
Edited by stevethe, June 16, 2016 - 04:19 PM.
  • stevethe
Posted June 16, 2016 - 05:13 PM
#59
This one is a 6 amp hour I wonder if it would work. http://www.revzilla....CFQ6oaQodtNkELQ
Edit: I think this one has about the same power as stock and will work fine.
Edited by stevethe, June 16, 2016 - 06:26 PM.
  • chelder
Posted June 19, 2016 - 04:53 PM
#60
Hey boys check this out had a battery custom made, 200cca 315 grams ImageUploadedByThumper Talk1466383934.558910.jpg ImageUploadedByThumper Talk1466383949.150971.jpg ImageUploadedByThumper Talk1466383961.037978.jpg ImageUploadedByThumper Talk1466383971.554536.jpg
I haven't got it yet it will be sent out today can't wait to test it!!
