2010 YZ450F won't idle after head gasket replacement
7 replies to this topic
  • MiranAdam16
Posted March 18, 2016 - 06:16 PM
Just did a head and base gasket on my 450f. The bike ran great before tear down, just would puke coolant after a hard run. Now when I start it, it will not idle at all. It sounds pretty rough as i give it a little gas. I turned the idle up and saw no changes. Any ideas?
  • MiranAdam16
Posted March 18, 2016 - 06:35 PM
used same valve shims as before and clearance was within spec
  • Monk
Posted March 18, 2016 - 06:38 PM
Clean the injector
  • MiranAdam16
Posted March 18, 2016 - 07:39 PM
Clean the injector
no change
  • Monk
Posted March 18, 2016 - 07:44 PM
no change
Timing correct?
  • MiranAdam16
Posted March 18, 2016 - 07:48 PM
Did it the way it says in the manual. We cant think of anything else it can be, going to tear it back down and redo the timing and valve shims
  • billygildark5007
Posted March 18, 2016 - 07:58 PM
There are two sensor connectors that will fit but not "click" in. I believe the ait (airbox) and the map (right side frame) sensor connectors.
Might be worth checking, ive made the same mistake with the same results. Their not color coded...
Any fault codes?
  • MiranAdam16
Posted March 18, 2016 - 08:57 PM
Any fault codes?
its a black 2 pin in the airbox, the other 2 i see are 3 pin and blue. i will swap the 2 blues and see, thank you!
that was the issue, hell yeah!
Edited by MiranAdam16, March 18, 2016 - 09:02 PM.
  • Hot  30 replies
  • Hot  50 replies
