raising seat height stiffening suspension on crf150
16 replies to this topic
  • ThomasTGH
Posted March 08, 2004 - 04:52 AM
My son is 12 years old 5'4"+ 150lbs and growing fast I want him to get this and next season out of his crf150f is there a way to raise the seat height and stiffen the suspension that anyone has tried? thanks
  • toneconsultant
Posted March 08, 2004 - 06:33 AM
BBR springs or other aftermarket springs will raise the bike about 2-3 inches. :)
  • 230F
Posted March 08, 2004 - 12:46 PM
Suspension links from BBR, then get the stiffer spring from BBR. I think Works connection is comming out with a shock!
The front throw in BBR suspension...
  • W1LD1
Posted March 08, 2004 - 03:59 PM
I used CR80 forks(whole front end) and rear shock. It will give that extra 2.5" you might want plus a much better ride. You need 1997+ used CR80/85 to work. You can either buy just what you need on e-bay or buy a whole bike and sell off what you don't. BBR and DMC use this on thier $7500-$11500 full race minis for adult riders. As your son gets bigger you can then get heavier springs and valving on this setup as needed for his weight and riding style. He may want to keep this bike a long time. :)
  • ThomasTGH
Posted March 08, 2004 - 04:20 PM
Awesome advice, thanks! if anyone else has input I'd appreciate it, but it sounds like he should have no trouble getting through a couple seasons!
  • 230F
Posted March 08, 2004 - 04:40 PM
I would just get the springs, then when hes older get a CRF 250
  • yak651
Posted March 13, 2004 - 07:43 AM
Any idea if the forks/tripple clamp off a '89 CR80 will bolt up to a CRF150? Tried looking for bearings on dennis kirk to see if part no.'s matched, but nothing for these models. Don't care that they are not inverted.
Thanks for the info if you have any!
  • dudleyscrf
Posted March 13, 2004 - 05:50 PM
you are probably not gaining much by putting on 89' forks, stock is 84-86 cr 80 forks , that is where the crf's forks , brakes and wheel come from.
  • 230F
Posted March 13, 2004 - 06:43 PM
Hmmmm. What you can do, is find out what year people are using. Try and find out if the dimentions on the other one, are comparable to the one you are looking for,=.
  • Modified150
Posted March 23, 2004 - 07:21 AM
Are you sure about that. I heard that only 96-current CR 80-85 front forks would fit the CRF150. Something to do with the bolt length of the Triple clamps. Also, the technology in the newer models has been improved.
  • FamilyRider
Posted March 23, 2004 - 12:55 PM
PRC sells a 2" taller seat foam for the 150 and 230 for about $80. It is a stiffer foam than stock.
  • Lunatic695
Posted March 23, 2004 - 03:00 PM
They also give a 10% disscount to all Thumper Talk members! :)
  • CRFMELIKE
Posted March 23, 2004 - 03:46 PM
prc :) Do you have the web site :D
  • FamilyRider
Posted March 23, 2004 - 05:34 PM
Here is the companies home page:
http://www.precision...components.com/
And here is the link to the seat (item 1109) $76.95:
http://www.precision...ndaacccont.html
  • CRFMELIKE
Posted March 24, 2004 - 08:28 PM
NOT FOR THE CRF230F :) JUST THE 150 :D
  • FamilyRider
Posted March 25, 2004 - 05:34 AM
I called PRC several months ago because I wanted to raise the seat on my son's 230. They told me it would also fit the 230. I choose to not get it because my son wants a softer seat since we do mostly recreational trail riding and his butt gets pretty sore after a long ride. This seat is stiffer than stock.
You might want to give them a call and double check.
  • CRFMELIKE
Posted March 30, 2004 - 04:59 PM
:D Thanks,i called prc they have it for the crf230f same price as the crf150 :)
Smaller bike for new teen rider by Parker_B30
  • 17 replies
Can rev bombing hurt your bike? by dave90
  • Hot  83 replies
230 Fork swap Spring 2016 - options by usedtobefast
  • Hot  57 replies
Indiana
OK, guys...Red Bird TT group ride Saturday 6/25...who's in? by Imposing Will
Dirt Bike   Dirt Bike Regional Discussion   Midwest
  • Hot  29 replies
Tires, Dirt Aggressive and DOT Certified by gliderboy
Dirt Bike   Make / Model Specific   Honda   CRF250 L/M
  • Hot  905 replies
