hole in swingarm....
11 replies to this topic
  • gofer412
Posted March 16, 2016 - 02:57 PM
I have a 2012 wr450f. The bike has had a chain slider on it from day one and had the chain the correct tension (right around 2"). went to replace the chain slider and found a hole. anyone ever see anything like this?
  • Bricktop72
Posted March 16, 2016 - 04:17 PM
Never seen it before, but it's scrap metal now.
  • J_YZ2fittyF
Posted March 16, 2016 - 04:19 PM
Nope, not if everything was "good" as you said it was. Looks like odd scuffing on the side of the swingarm too below that worn area.
Edited by J_YZ2fittyF, March 16, 2016 - 04:22 PM.
  • RockerYZWR
Posted March 16, 2016 - 05:29 PM
It's actually quite common, and there was another thread concerning that awhile ago on here. It started happening to my '11 but I caught it and cut a piece of galvanized sheet metal and applied it in underneath the chain slider. Yours looks pretty worn, but a competent welder may still be able to build enough off of that to fix it.
  • RockerYZWR
Posted March 16, 2016 - 05:31 PM
Here y'are:
http://www.thumperta...in-the-swingarm
  • WouldsAssassin
Posted March 17, 2016 - 07:50 AM
That's caused by sand and dirt between the slider and swingarm. Every vibration in the chassis and movement of the slider slowly sands away the aluminum.
  • GuyGraham
Posted March 17, 2016 - 10:17 AM
Noooooooo.......swingarm can be welded, as per my thread which is linked to in post #5
to the OP - make yourself a guard to fit between the slider and swing arm, as shown on page two of my thread, to save this happening to you again
  • gofer412
Posted March 17, 2016 - 10:42 AM
Thats from a piece of rubber I zip tied to the subframe to keep the chain from eating it. I heard that people have had problems with the wr450f chains hitting the subframe ( like mine) Thats why im super observant of the chain tension but never seen/heard of a hole under the chain slider like this.
  • GuyGraham
Posted March 17, 2016 - 10:46 AM
Very common
http://www.thumperta...r-to-swing-arm/
Edited by GuyGraham, March 17, 2016 - 10:47 AM.
  • gofer412
Posted March 17, 2016 - 10:51 AM
Thanks!!!
  • J_YZ2fittyF
Posted March 17, 2016 - 11:02 AM
Oh my bad, hadnt heard that, def dont follow wr450f talk much though either.
  • NightLite
Posted March 17, 2016 - 04:58 PM
Yes, this is quite common, I have a 14 that started making shiny spots from day one. I took the slider off, cleaned the area all up and put some red "rvt" silicon under and all the way around my slider, ran a nice bead around both sides. Now no dirt can get under it and wear on the swing arm.
A good friend has a 13 that he purchased after I got mine, laughed at what I did, then 6 mos later was calling me bitching about how his is starting to wear. He has now since done the same thing.
A sharp razor blade will take off the silicone easy enough once I need to replace the slider.
