09 YZ450F shock on 07 WR450F
5 replies to this topic
  • 2strokeYardSale
Posted March 16, 2016 - 09:48 AM
Will a 2009 YZ450F shock fit and work on a 2007 WR450F?
  • Krannie McKranface
Posted March 16, 2016 - 10:56 AM
yES
  • 2strokeYardSale
Posted April 03, 2016 - 02:07 PM
Apparently not. The bottom of the shock won't fit in the linkage. I measured and it's wider than the WR450F.  The part numbers for the collars are different.
  • stevethe
Posted April 03, 2016 - 02:16 PM
What doesn't fit.
  • 2strokeYardSale
Posted April 04, 2016 - 08:29 AM
The width of the collars is too much for the width of the linkage. It could be because I'm using WR collars. The YZ shock uses the same bearing/bushing, the same seals, but different collars.
  • 2strokeYardSale
Posted April 06, 2016 - 08:17 AM
I got the new YZ collars and they are even wider than the WR collars. I figured either the wrong bearing was in the YZ shock, or the layer of rust on it spaced out the collars too wide for the linkage. So I tried to remove the bearing and ended up with it partially trashed and partially stuck in the shock. FML. I don't know if I can dremel it out or what.
