02 426 linkage/shock/swing arm bearing question
7 replies to this topic
  • 0bigsilver6
Posted March 14, 2016 - 05:50 AM
Will ALL the bearings from all three of these parts press out from either direction? The swing arm bearings look like they have a bigger diameter hole on the outside than on the inside. I gotta press them out today while at work and I forgot my manual. Please help!
Posted March 14, 2016 - 06:45 AM
The swing arm and the connecting link bearings sit in stepped bores.  They have to be pulled form inside to out only.
  • 0bigsilver6
Posted March 14, 2016 - 06:52 AM
Which part is the connecting link?
Posted March 14, 2016 - 07:01 AM
The U shaped link that connects the relay arm to the frame.
  • 0bigsilver6
Posted March 14, 2016 - 07:04 AM
Got it! Now that you say that I see there is a step down in it. Thank you!
  • 0bigsilver6
Posted March 17, 2016 - 10:26 AM
New question. I screwed up some of the bearings in the linkage so I ordered a couple replacement Yamaha bearings. There is this yellow wax liner in the needle bearing, and I supposed to remove that?
Posted March 18, 2016 - 06:18 AM
That's the "permanent" built-in lubricant.  Personally, yes, I would remove it and pack the bearings with a good grade of marine rated high pressure grease.
  • 0bigsilver6
Posted March 18, 2016 - 07:31 AM
That's what my thoughts were as well. All the pivot works bearings were bare and I had to pack with grease. Will do with the Yamaha ones as well, thanks for the info.
  • Hot  30 replies
  • On January 15, 2017
  • 5 replies
  • 0 replies
  • Hot  36 replies
