Bike Won't start when hot
8 replies to this topic
  • the.brains
Posted March 12, 2016 - 11:28 PM
Hey guys
So I'm really at my wits end with my 2013 yz450f .
I changed my spark plug to the cr8eix, replaced my idle/hot start plunger and cleaned the throttle body.
I fired her up 2-3 kicks and warmer her up before killing. I geared up and tried to start, nothing. I felt a kick back 1 or 2 times after kicking through the stroke.
I then push started her to get going, but she would not start any other way throughout the entire day.
What old be wrong? What am I missing out?
  • Slow and Jerky
Posted March 13, 2016 - 05:25 AM
I would check the valve clearances. You said you cleaned the throttle body, did you pull the the injector and clean it (using a battery so the plunger was moving)?
  • the.brains
Posted March 13, 2016 - 07:33 AM
Hi slow.
Valve clearances were done 8 hours ago.
No I didn't do this. I didn't remove the injector, although I did run injector cleaner through it in my previous tank of fuel.
Could you advise me on how to connect to a battery and what to clean with ?
  • Slow and Jerky
Posted March 13, 2016 - 07:42 AM
I would still check the clearances, the thing about the valves on these is that as they wear they get tighter and eventually you lose enough compression that it makes it so it won't start with the  kick starter but bump starts fine.
Here is a video for cleaning an injector
It's not a bike injector but the same principle. You will need a torx bit with the little hole in the end, the head on the screw is one of those security heads, I don't recall the size, but it's they are nothing special.
  • the.brains
Posted March 13, 2016 - 08:54 AM
Thanks so much Slow.
I will check my valve clearances and clean my injector. Will report back once completed.
  • Krannie McKranface
Posted March 13, 2016 - 05:18 PM
I would add that you need more pressure to get a good cleaning
Add a rubber tube to the input to the injector
Fill it up with solvent
Insert an tapered airhose tip
Clamp all in place
Now cycle the injector with 90psi of solvent behind it
Spray the injector into a white rag, and stop when no more color comes out
  • the.brains
Posted March 15, 2016 - 11:12 AM
So I finally got time to strip her down. Set her to TDC and immediately I noticed she was 1 tooth off on the exhaust cam. I set her correctly and checked valve clearances- all perfectly within range. I didn't go any further down to clean the injector.
I bolted everything, 2 kick she fired up, let her run for 10 minutes of so to warm up. Killed and she fired back up first kick so everything seems to be resolved... Yay :) thanks very much everubody
  • Slow and Jerky
Posted March 15, 2016 - 11:17 AM
That's good to hear, but you should seriously consider replacing your timing chain, if it jumped once it will do it again and could be much more catastrophic.
  • the.brains
Posted March 15, 2016 - 11:28 AM
Hey slow.
I replaced the chain < 10 hours ago.
I think the timing was wrong when it received the bike back from the shop.
  • 0 replies
  • Hot  36 replies
  • Hot  50 replies
  • On January 15, 2017
Motocross
  • Hot  491 replies
