Glowing red exhaust 05 wr450
8 replies to this topic
  • Gregorycolebourn
Posted March 10, 2016 - 08:15 PM
Bike ran fine. Changed the oil and filter, cleaned carb jets put it back together and this is happening. Too much air but from where?? Thanks..
  • Krannie McKranface
Posted March 10, 2016 - 08:30 PM
What does 'cleaned the carb' mean to you?
Reaming the jets is not 'cleaning the carb'....you probably pushed debris into the passage above the pilot jet...
Where is your fuel screw set?
Did you check the hot start, and cable nut for leaks?
Does it idle?
  • Gregorycolebourn
Posted March 12, 2016 - 05:34 PM
Dropped the bowl and removed the jets. Soaked them in mystery oil for a bit then blew compressed air through everthing. Fuel screw 1 1/2 turns back from closed. Have not checked the hot start and cable nut yet.
Posted March 12, 2016 - 05:59 PM
Blowing compressed air from the bottom up guarantees you blow any loose debris up into the narrower carb passages...
You probably have partially clogged the pilot jet passage and the fuel screw passage
Ream them with #15 fishing line and REPLACE your pilot jet with a brand new one
  • Gregorycolebourn
Posted March 12, 2016 - 06:14 PM
Ok. Back at it tomorrow. Thank you for your help and input!
  • bobpara
Posted March 13, 2016 - 04:37 PM
OMG! I have never seen a pipe that hot!....good time to remove any dents !
  • JVP
Posted March 15, 2016 - 08:00 AM
These pipes will glow red at idle, but I never seen one that red.  That can not be good for the motor.......
  • 2009wr450
Posted March 15, 2016 - 11:57 AM
This guy knows.
  • k.g
Posted March 15, 2016 - 11:58 AM
Did you read the FAQ?
