Sprocket change. 14 & 51 to a 13 & 49
5 replies to this topic
  • supermo26
Posted March 07, 2016 - 03:32 PM
Looking to make bike a little less torque and a little faster on the top end.
What would going from a 14 tooth front 51 tooth rear to a 13 tooth front to a 49 tooth rear do?
2005 yz450f with a 4 gear transmission.
  • Krannie McKranface
Posted March 07, 2016 - 03:37 PM
www.gearing commander.com
14/51 is (not) LOWER gearing than 13/49
:facepalm:
Edited by KRANNIE, March 10, 2016 - 08:32 PM.
  • JDLowrance
Posted March 07, 2016 - 07:12 PM
Actually 13/49 (3.77) is shorter/lower than 14/51 (3.64) and will do the opposite of what you're after. Sounds like you're looking for less snap and a little more top speed. Dropping a tooth or two from the rear and maintaining the 14 front will get you there.
When I desert raced my 03 450 (4 speed) I was running 15/42 (2.80) which would still loft the front in 4th with ease and top out at 175kph (110mph).
  • BongKarem
Posted March 10, 2016 - 08:10 PM
Here i found a great solution, a gearing program :thumbsup:
http://www.gearingcommander.com/
Hope that helps
  • DESERTJUL
Posted April 03, 2016 - 10:19 AM
Hope that helps
They left off 06 WR450.
  • DESERTJUL
Posted April 03, 2016 - 10:28 AM
The guy I bought from gave me a box of old stuff. Theres a 15 and 44 in the box, used but will work for testing. What he put on it is 14/50. I'm getting 35 mpg now. I like the way it handles, it will do 75 on the hwy but still handle the slow technical stuff. I'd like to get a bit better gas mileage without losing the technical. Any suggestions?
Edited by DESERTJUL, April 03, 2016 - 10:28 AM.
