Brembo 4pot caliper with stock master cylinder
4 replies to this topic
  • jorgen_blok1
Posted March 02, 2016 - 09:45 AM
As the title says.
Will the brembo caliper with 320 disc work well with the stock 11mm master cylinder.
  • knuckleduster271
Posted March 02, 2016 - 12:13 PM
As the title says.
using your stock dirtbike master is a bad idea and a waste of a good caliper.
If its a 4 pot brembo 13mm mc is the way to go.
If you want out cheap get a trx450r quad master cylinder.
They are 13 mm, come with a brake light switch already installed.
Very good mc for the $$.
I might have one laying around if your interested.
I upgraded to a radial mc on my bike but ran the trx for a couple years and it wasnt bad at all.
Heres some info on them if you wanna check it out.
http://supermotojunk...master-cylinder
Edited by knuckleduster271, March 02, 2016 - 12:47 PM.
  • jorgen_blok1
Posted March 02, 2016 - 01:50 PM
Thnx a lot I'll look one up.
This way I can switch the intire brake system when switching to enduro wheels Instead of having to fit a 320 disc of switch calipers all the time.
  • knuckleduster271
Posted March 02, 2016 - 03:45 PM
I just looked through my old parts- i still have it.
$35+ the ride and its yours-
  • jorgen_blok1
Posted March 02, 2016 - 11:49 PM
Well I'm from Europe so it's best to look one up over here
