Flywheel Weights
14 replies to this topic
  • Ron_S
Posted May 11, 2001 - 05:15 AM
I am using a Baja Design 7oz weight now. When I got mine, that was the only size available. The guy that makes them said he was going to make a 10oz weight. I just read a post that Monty is using a 12oz weight. The 7oz weight helped a lot over stock, but we do a lot of tight riding, and I'm thinking heavier may be better. Can someone enlighten me on this? Thanks, Ron
  • PMAUST
Posted May 12, 2001 - 05:17 AM
Ron, go back to my post on Clutch Basket. Monty replied to you there. Also, check out Terrycable.com. They have flywheel weights up to 12 oz.. That is where I ordered mine. Paul
  • MONTY
Posted May 12, 2001 - 07:39 PM
Ron
Hi Monty here, i run stock timing (WR) and love the 12oz, flywheel I have used it from day one also i run stock muffler with a TTR250 tip it has a larger hole in the end cap then the WR one doe's, change the pilot jet to next size up works geart.Also run the 13 tooth frt gear most of the riding is on tight trails and woods but i can still get out on the roads and fly, in death vally we running down the roads at 80 to 90 MPH.
monty
  • Ron_S
Posted May 13, 2001 - 01:50 AM
Monty, Thanks for the info. Did you go up 1 size on the pilot with the TTR tip? I am using the Baja Design tip, and it works well. I have the stock pilot in still, and my plug looks good. I am going to get a 13 tooth primary this week. Have you considered raising your fork tubes? I am thinking about it. I,ll let you know how it works. Ron[QUOTE]Originally posted by MONTY:
  • bender647
Posted May 13, 2001 - 04:18 AM
Is installation of a flywheel weight
a bolt-on affair? I recall reading
something in the archives about
JBWeld. These aren't epoxied in place?
  • Ron_S
Posted May 13, 2001 - 08:11 AM
JB Weld and bolt on. You need a flywheel puller, and a spanner wrench. I made one. It took about 1/2 hour. It's pretty easy, just lay your bike over on the kick start side to drain the oil out of the case or it get's messy. Being an old 2 stroke guy, boy was I supprised. I am considering a 12oz weight.
  • cueball
Posted May 14, 2001 - 05:13 AM
Okay, I rode with the newly installed 10oz weight for the first time on Saturday. I got the 10oz Terrycable from Baja Designs.
If you ride tight stuff, this is a no-brainer!! Why I rode the WR for two seasons without it is the real question.
It (maybe) mellowed it a tiny bit in the mid-range, but I can't even be sure of that. What it did do is decrease flame-outs by about 70%. Just what I was looking for.
I'd do the 12oz next time. Since the 10 didn't noticably detract from performance, why not go the extra 2 oz?
  • Guest_Guest_*
Posted May 14, 2001 - 05:21 AM
What is the stock flywheel weight??
  • bender647
Posted May 14, 2001 - 07:09 AM
I guess my real question is, can you
undo it? You are gluing a weight onto
your motor?
  • cueball
Posted May 14, 2001 - 08:01 AM
I didn't JB Weld mine. The kit I purchased was bolt-on, although you have to drill & tap (tools included!) 3 new holes.
I'm assuming that the 6 loctited bolts will hold this puppy in place.....I hope so! I guess the beauty of no JB Weld is that I can remove it if I feel like it. At this point I can't imagine why I'd bother.
  • Guest_Guest_*
Posted May 14, 2001 - 12:54 PM
Here is exactly how to install a flywheel on my 2000 YZ426. It should be exactly the same for the WR.
http://members.home....el/yz426fly.htm
Roostn in Golden
  • Ron_S
Posted May 15, 2001 - 10:14 AM
The guy that made mine said all you have to do is tap the weight with a hammer and punch, and it will seperate. I used JB weld because it was in the installation page with the weight. Ron S
  • Guest_Guest_*
Posted May 15, 2001 - 10:28 AM
Let me re-word this. What is the weight of the stock flywheel weight???
  • MONTY
Posted May 15, 2001 - 10:44 AM
Mike 68 I think the stock flywheel (WEIGHT)
is (with out the ad on weight)is about 2oz i think i read that some were can;t rembber, if some one knows post it.
  • Ron_in_SoCal
Posted May 15, 2001 - 10:53 AM
I run a 10 ounce weight and love it. The primary reason I chose to run one was wheel spin. I was having trouble getting the power to the ground, especially in technical terrain. Don't be fooled into thinking there is not a trade-off. You will lose some snap, but it works for me. Oh yeah, no JB weld on the Terrycable weight. If you want to remove the weight, why not just get another flywheel ($170) and a puller and swap 'em as needed?
Mike68, I'm not sure what the stocker weighs. It's a good question. Anyone know? I think I read somewhere that the stock wr flywheel is 17 ounces heavier than the YZ.
Here is a good one: The Yamaha dealer in my area told me that if I put a 10 ounce weight on my flywheel I will end up snapping my crankshaft in two and Yamaha will not replace it. He highly recommended I change my gearing (15/48) to resolve my wheel spin problem. Yeah right!
