2007 WR450 - good buy?
4 replies to this topic
  • NLRichyJ
Posted February 25, 2016 - 01:40 PM
Hey guys I am looking at getting a bike for SM, found a 07 WR that has 12k kms for $3500 (Canadian). It's plated but doesn't have a SM wheel setup, but has had the top end done a couple thousand ago with apparently a better piston.
I am curious what's the typical longevity for these bikes? Anything to look for in particular?
Was going to get a '14 and swap it back and fourth to dirt but I get the feeling of rather have two separate bikes.
  • stevethe
Posted February 25, 2016 - 02:10 PM
They go a long time. But hopefully whoever did the work did a proper job.
  • beairmo
Posted March 05, 2016 - 04:07 AM
The 07-09 WR450F has a "stutter" when the ECU map switches. This is not a big deal at all off road. You don't feel it all. But on the road, you will go nuts.
I would test ride it on the road and see how the stutter is. Some bikes have it, some not so much. Its all about the TPS and how dialed in it is.
  • stevethe
Posted March 05, 2016 - 06:47 AM
Putting in a Dynatek ignition on the torque setting removes the stutter.
  • Krannie McKranface
Posted March 06, 2016 - 06:42 AM
The ignition studder is felt as partial throttle, and is eliminated by unplugging the TPS.
This will reduce throttle response and acceleration about 10% however.
As mentioned, a Dynatek ignition will cure it (about $300)
