what handguards for my WR??????
26 replies to this topic
  • wrjay
Posted March 06, 2004 - 08:02 AM
i am looking at ordering some acerbis rally2 handguards for my 02 wr,and am wondering how they fit,or if anybody has any suggestions to better products.
  • bonecrusher69
Posted March 06, 2004 - 08:25 AM
Ive read several posts about the acerbis hand guards and most said they dont fit or you have to modify them. Check out the wacker brand guards. You can get them from rocky mountain. They fit good and require no modifying. :)
  • Agent
Posted March 06, 2004 - 08:30 AM
I put the Rally Pro handguards on mine and they went on no problem. Most of the guys I ride with use the Rally Pro guards as well. Rally 2's don't have the aluminum bar and aren't as durable I'm told (never tried them personally)
  • Fryboy
Posted March 06, 2004 - 11:45 AM
Hi,
I wouldn't recommend the Rally Pro's for the WR426. I used them, and don't get me wrong, they have saved my hand from probable destruction :D But IMO they are a little soft. The metal isn't the strongest on the market. I wasn't to happy with the mounting hardware either. Strips very easily. Whenever I would drop my bike the guards twisted causing interference with throttle, front break lever, and clutch lever. Might be a bit better with Triple clamp mounts :)
I ended up buying Enduro Engineering this time around. These are much more durable. The metal is soo strong I wouldn't want to see the crash that could bend them. They don't twist as easily when you drop your bike and/or hit a tree. The hardware is a lot more heavy duty. All around great guards :D Oh, and I have tested them a bit too :D
Fryboy
  • cmore
Posted March 06, 2004 - 12:31 PM
I have the cycres probend with triple clamp mount, totally
indistructable. mounted easy. & I'm still running the stock bars, & we all know how soft these bars . I've taken some pretty serious tumbles. nothing bent. 02 wr426 I'll be buying another set for my 01 yz426, they are that good. :)
  • foursmoke
Posted March 06, 2004 - 02:57 PM
Ditto on the Cycra pro-bends w/tipple clamp mounts :D. They are very well made but alittle pricey.
Smoke :)
  • yimmyhauler
Posted March 06, 2004 - 03:57 PM
I used the Tusk D-Flex on my originals and upgraded them to the Pro-Taper mounts when I bent the sh!& out of my stock bars ... they work well and cost effective.
  • MasiveMoe
Posted March 06, 2004 - 04:05 PM
Our team uses Factory 909 Mashers. They are extremely strong. We like the Cycra Pro-Bends as well. Sidi/Motonation also makes some called the "Whacker", that are identicle to the Factory 909 Mashers. I would recommend one of these three.
Moe
  • SBG
Posted March 06, 2004 - 05:11 PM
Ditto on the Cycra pro-bends w/tipple clamp mounts :). They are very well made but a little pricey.
Smoke :D
Yeah, but you and I saw how Butchie trashed his on the throttle side! :D Of course he was floating in the clouds for a day or two after that one. :D Basically, if you bend them, don't expect to not have something messed up on you or the bike.
  • holeshot426
Posted March 09, 2004 - 07:38 AM
another vote for EE guards. Way stronger than Acerbis and mount better.
  • tigerowner_ut
Posted March 09, 2004 - 08:26 AM
I second the opinion for the Tusk Guards. Much better than the Acerebis guards
  • DOGBITE
Posted March 09, 2004 - 08:44 AM
I've only used the rally pro's .I like them and I fall down alot. :)
  • banffboy
Posted March 09, 2004 - 09:32 AM
Hi,
Fryboy
Enduro Engineering :D Way better than the Acerbis
  • Canuck
Posted March 12, 2004 - 12:20 PM
Hi,
I wouldn't recommend the Rally Pro's for the WR426. I used them, and don't get me wrong, they have saved my hand from probable destruction :D But IMO they are a little soft. The metal isn't the strongest on the market. I wasn't to happy with the mounting hardware either. Strips very easily. Whenever I would drop my bike the guards twisted causing interference with throttle, front break lever, and clutch lever. Might be a bit better with Triple clamp mounts :D
I ended up buying Enduro Engineering this time around. These are much more durable. The metal is soo strong I wouldn't want to see the crash that could bend them. They don't twist as easily when you drop your bike and/or hit a tree. The hardware is a lot more heavy duty. All around great guards :) Oh, and I have tested them a bit too :D
Fryboy
fryboy: do you have a link for enduro eng.? I just broke my 2nd set of acerbis rally pro's and am looking for something different/more durable.
cheers
  • Scuba_Steve
Posted March 12, 2004 - 06:27 PM
I've been using the Wacker guards for 2 years now, and they have really held up well after repeated crashes. It's cool also to be able to replace the plastics on them. I got mine from Motonation.
  • oldbones
Posted March 12, 2004 - 06:37 PM
The whackers and the Tusk Dflex are pretty much identical, except for the price. Check out RockyMountainMC.com the tusk are about $50, and adapters for fat bars are like $15 more. I have tried pretty hard, and can't seem to damage these guards. I have only got it to slip once, and RIDE can tell you about that one...
  • cyc
Posted April 30, 2005 - 12:13 AM
Hi there,
I definitely need handguards (or should I say "brake/clutch lever guards :naughty: ) for my WR 400 2002.
I come from Europe, and as I see we have totally other brands to choose from. Well, almost ... Enduro Engineering, Tusk, ... I've heard for none of these - till now, after reading this thread :naughty:
Almost a year ago I ordered handguards from Zupin, the manufacturer is Polisport - I'm quite sure in the US nobody ever heard about :D And ... well ... they don't fit. They are in nice yamaha blue color ... but don't fit on my WR. :D The front brake hydraulics makes it impossible to mount on the handlebar :D
I'm looking for an alternative ... the brake lever breaks too easily ... :D
I've checked the
Enduro Engineering guards - looks nice, but there are a lot of items to choose from ... and I have no idea what would really fit on my WR 400. The next bad thing is that - if they do ship to Europe - the price will be at least twice as much as in US :cry: (postage, taxes etc.)
  • Chevy_Cowboy
Posted April 30, 2005 - 01:00 AM
Cycra Pro Bend guards are TOUGH, if you hit something hard enough to hurt them or the levers behind them, you have way more to worry about than broken levers :naughty:
They're not cheap, but the best seldom is.
  • PeakRider
Posted April 30, 2005 - 04:29 AM
I like the Tusk D-Flex. They are inexpensive, strong and compact. They provide enough room for the levers and your fingers and don't stick out very far. I also like the optional larger plastic shields for cold weather.
  • Bamster
Posted April 30, 2005 - 04:37 AM
I have Enduro Engineering. :naughty:
