2001 YZ426f problems
9 replies to this topic
  • dirtpaw12
Posted February 23, 2016 - 04:13 PM
Just got the bike, had to change the spark plug to get it running plus rarely will crank while kickstarting mostly just bumpstarting, and the muffler glows darkesh red, maybe it's because I'm riding with the choke on because will only idle with it on???? Suggestions
  • tmeyer37
Posted February 23, 2016 - 05:19 PM
The first thing you should do is pull the carb apart and clean it. It is likely a clogged pilot circuit that is causing you to leave the choke on.
  • dirtpaw12
Posted February 23, 2016 - 05:23 PM
We cleaned the float bowl
What about the glowing muffler?
  • tmeyer37
Posted February 23, 2016 - 05:26 PM
 Cleaning the float bowl isnt going to change anything. You need to clean out the passage ways and jets. A clogged jet means that the bike wont get enough fuel which is why you need to use the choke.
When you say muffler, do you mean the end muffler/silencer or the header ( portion that comes out of the front of the motor)
  • dirtpaw12
The header
  • tmeyer37
Posted February 23, 2016 - 05:56 PM
The header
If it is happening when your are idling for an extended period of time that is fairly normal. Cleaning your carb may reduce this though because it seems your bike is running lean which can lead to higher operating temps
Posted February 23, 2016 - 10:08 PM
The header glow is normal up to a a point, but the fact that it won't stay running without the choke on is a pretty clear indication that the pilot jet is blocked.
  • dirtpaw12
Posted February 24, 2016 - 04:56 AM
Okay so blew all the jets out with airhose and still won't idle will take off and stick a needle through them and if that don't work should I order a rebuild kit?
  • Baldwin
Posted February 26, 2016 - 03:14 AM
You can try just a new pilot jet if you don't feel like paying for the whole rebuild kit right off the bat.
Posted February 26, 2016 - 07:32 AM
Air won't help.
http://www.thumperta...o/#entry6879695
  • On January 15, 2017
  • 10 replies
  • Hot  113 replies
