yz426f problem
6 replies to this topic
  • copeking
Posted February 20, 2016 - 07:08 PM
So i purchased a 426 blown up i rebuilt it new head new jug new piston, shimed valves into spec, i set timeing chain and it started right up ran it 10 seconds, then i had to remove the head i broke the bottom half of the plag and it got stuck in the hole, i reused head gasket and now kicks over east without comp release did i mess up the cam timing? I checked it a dozen times tried everything im debating if the head gasket could cause the loss of compression and poping out of exaust,? Or is my timing somehow off? Befor someone says it yes it has fule and spark
  • 870
Posted February 20, 2016 - 08:26 PM
What's a plag?
  • bigduff
Posted February 21, 2016 - 04:24 AM
If it kicks easy without the compression release, you have a head or valve sealing problem. Those bike are in-lockable without the comp lever.
  • orangyktmthing
Posted February 21, 2016 - 05:51 AM
Why would you reuse a head gasket?
Posted February 21, 2016 - 07:18 AM
NEVER reuse a head gasket that has been torqued in place, whether the engine was run or not.
  • copeking
Posted February 21, 2016 - 07:21 AM
What's a plag?
i ment plug sorry
  • copeking
Posted February 21, 2016 - 07:23 AM
so im assuming is the head seal beacuse 2 days ago it had great compression,
  • Hot  36 replies
  • 0 replies
