Quick FCR carb question
2 replies to this topic
  • Monkeybutt2000
Posted February 20, 2016 - 02:25 PM
What is the brass nipple in the carb throat that shoots the fuel called? Is it removeable? I almost feel stupid asking this :blush:
  • Krannie McKranface
Posted February 20, 2016 - 02:53 PM
It's called the accelertor pump nozzle, and yes it is removable, but DON'T try unless you are skilled at it.
If it's clogged, you can use a piece of ultra-fine wire and real solvent carb cleaner to clear it out.
  • Monkeybutt2000
Posted February 21, 2016 - 02:22 PM
Thanks,I'm "skilled" but probably should leave it alone. I tried a welding tip cleaner to try and clean it bit it was a smidge to big. I've been soaking it with a q-tip soaked in seafoam.
  • Hot  50 replies
  • Hot  36 replies
  • Hot  47 replies
  • 5 replies
