Exhaust popping 08 yz450f
5 replies to this topic
  • Rider1998
Posted February 16, 2016 - 10:44 PM
Bought a 08 yz450f bike is immaculate in every way an older gentleman owned it and everything is all original from factory but suspension upgrades. Only question I have is it pops when reved and on deceleration but starts going away the warmer it gets just wondering if that is ok
  • 15thumper
Posted February 17, 2016 - 04:44 AM
Sounds lean pop on decel is normal if not excessive if power loss also then might be more serious like bent valve I'd check pilot jet maybe bump it up I always ran a jd jet kit in my 08 and it was real snappy
  • stevethe
Posted February 17, 2016 - 06:12 AM
It's okay fine for a 08 YZ450 putting a bigger pilot in it may lesson it a little.
Posted February 17, 2016 - 07:33 AM
Before doing anything to the carb, be sure you don't have a leak in the exhaust system causing this.  It would be at either end of the header.
If the pipe's OK, then try setting the pilot screw according to the manual.  If that fails to reduce it to a normal level, then go up a jet size on the pilot, but not until you're sure it needs it.
It's normal for the bike to pop a little some of the time.  It means it's jetted right.
http://www.thumperta...t/#entry2983539
http://www.thumperta...ircuit-setting/
  • Rider1998
Posted February 17, 2016 - 03:27 PM
This thing pops a lot on decel and if you rev it
Guy said the carb was rebuilt with oem stuff and has only had two rides on it. Air screw was 1 3/4 turns out when I got it I bumped it to 2 1/2 and it still does it
  • Rider1998
Posted February 17, 2016 - 07:58 PM
Carb is dirty and I fell to the devil carb cleaner I couldn't remember what rubber would ruin but the slide seal is gone bike has stock jetting 160 main and a 45 pilot 3rd clip position. Question would I have to do any jetting difference with a factory 4.1 slip on no header just the muffler thank you for your help
  • Hot  28 replies
  • 10 replies
  • 0 replies
  • Hot  30 replies
  • Hot  38 replies
