YZ450 Crank rebuilding
2 replies to this topic
  • MXRose3
Posted February 16, 2016 - 01:19 PM
I've rebuilt plenty of two stroke cranks before, but I'm stumped by the 4 stroke big end bearing pin.   It has two small holes in one end.   Does it matter which side crank web it gets pressed into?
I can't see it making much difference in terms of weight offset.    Just curious if anyone has done there own cranks on these bikes.
Posted February 16, 2016 - 02:00 PM
Yes, it makes a difference.  Those are the oil passages that lead to the rod bearing.  They go into the RIGHT side crank axle/flywheel, where they align with the groove in the inside of the pin bore that carries oil up from the right side end of the crank.
  • MXRose3
Posted February 16, 2016 - 07:52 PM
Thanks!
  • 10 replies
  • Hot  36 replies
  • Hot  38 replies
