First 4 stroke yz426
4 replies to this topic
  • justinpage426
Posted February 15, 2016 - 11:59 PM
Well I picked up my first 4 stroke dirtbike and it skipped timing so I tore it apart and the engine would still turn over freely but the cam chain was bad and had some links seized on it. Replaced the cam chain and reassembled but when I got the timing set i tried to turn the motor by hand and when the camshaft lobs touch the valves it just stops moving and won't rotate. I haven't put much force on it at all. So I'm stuck and can't figure out why it's doing that. Could it be from not having the tensioner in? Or from turning the motor over several times after having the cam chain and cam shafts off it. I'm just stuck and can't figure this out. It's an 01 yz426.
Posted February 16, 2016 - 07:07 AM
Absolutely.
  • justinpage426
Posted February 16, 2016 - 12:00 PM
Ok going to try and put the tensioner in and see if the camshafts will roatate
Posted February 16, 2016 - 12:08 PM
In order to install the tensioner, you must back it all the way off and lock it there, then bolt it in place, then unlock it.  The center tower part of the tensioner has a 10mm hex bolt in it.  Remove this, then use a small screwdriver on the tensioner screw to retract the tensioner plunger.  It should stay in place like that if you get all the way to the end of the travel.  Once in place, use the screwdriver again to fudge it back forward until the spring takes over.  Then replace the center bolt.
Download a manual:
http://api.viglink.c...uals/index.aspx
http://api.viglink.c...ook.com.au/?r=0
  • justinpage426
Posted February 18, 2016 - 03:20 PM
Thanks it was the problem
  • 3 replies
  • 10 replies
  • On January 15, 2017
